FS: Rockford Fosgate 25 to Life Power 1000 5 Chan beast - Car Audio Classifieds!
Old 03-02-2010, 04:12 PM
0/11 sssssss33
Default FS: Rockford Fosgate 25 to Life Power 1000 5 Chan beast
Rockford Website
Number of Channels 5 Rated Power
continuous power
Front/Rear Channels
50W x 4 @ 4-Ohms RMS
100W x 4 @ 2-Ohms RMS
150W x 4 @ 1-Ohm RMS
200W x 2 @ 4-Ohms Bridged Mono
300 x 2W @ 2-Ohms Bridged Mono
Sub Channel
300W x 1 @ 4-Ohms RMS
600W x 1 @ 2-Ohms RMS
800W x 1 @ 1-Ohm RMS
Total Power
total sum of 'rated power'
1400 Watts Dynamic Power
powercube measurement (info)
Front Channels
111 Watts x 2 @ 4-Ohms 0 Res
185 Watts x 2 @ 2-Ohms 0 Res
267 Watts x 2 @ 1-Ohm 0 Res
Rear Channels
187 Watts x 2 @ 2-Ohms 0 Res
272 Watts x 2 @ 1-Ohm 0 Res
Sub Channel
832 Watts x 1 @ 1-Ohm PVC
Bridgeable Yes (front/rear) Crossover Controls Front Channels
High-Pass (HP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch
Rear Channels
Sub Channel
Low-Pass (LP): 32-250Hz 24db/Octave Linkwitz-Riley
Infrasonic filter: 28Hz fixed
Tone Controls Bass: 0dB to +18dB @ 35-75Hz (sub channel) Signal Input Low level: 3 RCA pair
Signal Input Switch: 2/4/5
Signal Output n/a Power Input Connector Block Power Wire Gauge 1/0 AWG Speaker Output Connector Screw terminal barrier strip Speaker Wire Gauge 12 AWG Heat Sink Type Cast aluminum Cooling Fan Cooled Remote Controls ParaPunch Bass EQ (included with cable) Visual Indicators Power On
Thermal
Output Short Circuit
Fan On 3 Stage Termal
Low B+ Voltage (below 11VDC)
5-channel Level Monitors
Circuit Topology Class Front/Rear Channels
Class A/B
Sub Channel
Class BD
Frequency Response Front/Rear Channels
20Hz to 20kHz +/- 0.5 dB
Sub Channel
20Hz to 250Hz +/- 3dB
Shipping Weight 13 Lbs.
(5.9 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 23 (in)
6.6 x 32.51 x 58.42 (cm)
Ran the amp for 6 months without a hitch, not a single shutdown or anything. I have never pushed the amp hard at all. It has a coupe scratches on the chrome and one of the screws for the speaker input is stripped, it can still come out if you use a flathead but i just attached a wire so i wouldn't strip it more than it already was. other than that the amp works 100%
This thing is a beast and will surely put out more than rated.
Physical: 7/10
Mechanical: 10/10
4. Price: : 420Shipped OBO
Did the best i could to get a picture of the one speaker outlet
A quick pic of it working
Old 03-02-2010, 05:48 PM
0/11 sssssss82
any trades?
Old 03-02-2010, 09:50 PM
0/11 sssssss33
No trades sorry
Old 03-02-2010, 09:55 PM
0/11 ssssss267
Good luck with the sale. I ran one of these for a while and loved it. Very clean strong amps.
2004 Blazer Zr2
Old 03-02-2010, 09:57 PM
lantz's Avatar
0/11 sssss1030
i ran (4) 18" RF subs and 4 component sets off of mine..very good amp!
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
X2. I miss mine. One of the sexiest amps I ever owned. and great clean power out of it.
Old 03-03-2010, 03:42 PM
0/11 sssssss33
Thanks guys, also i forgot to mention that the remote bass knob is also included
Old 03-07-2010, 01:13 PM
0/11 sssssss33
Bump
Old 03-08-2010, 01:06 PM
cant_get_ryte's Avatar
0/11 sssssss32
350+ship? I cant really justify more...just wanna play around with it...
Good Days Dont Last...RIP Phonzo...04/19/08
Alpine 505-P1/Alpine H701+CUX/MTX-TE1004/2xMTX-TE1501/ Rainbow CS 365 P2's Active/2-RE XXX's
/Nissan Forums...
FEEDBACK ON CA Forums
Speedfreak28,Valter,6spdcoupe,teamquakecelica,Sque ak12, MoeLester, Marshallb,nismos14, HD Racing, GoingDef154,djvi0lent,Frito,plyer3,grizzly02,Macs, 90Accordman
Old 03-09-2010, 01:36 AM
0/11 sssssss33
Sold!! Thanks guys!
FS: Rockford Fosgate Punch 45 25 To Life itsmyturn 2-Channel Amplifiers 2 06-24-2009 11:58 PM
FS: Rockford Fosgate Punch 75 25 To Life itsmyturn 2-Channel Amplifiers 2 06-19-2009 06:18 PM
[SOLD] Rockford Fosgate Power 1000 O/S RetroAudioInc Multi-channel Amplifiers 4 03-27-2009 08:28 PM
[SOLD] Rockford Fosgate Power 1000 25 to Life - 5 Channel K-Mac Multi-channel Amplifiers 5 11-07-2008 07:07 PM
[SOLD] Rockford Fosgate Power 1000 Mosfet Old School Slam Multi-channel Amplifiers 6 10-29-2008 09:12 PM
