[SOLD] Directed 600/4 Class A/B 4 CH Amplifier 125x4 RMS@2ohm - Car Audio Classifieds!
Old 04-23-2010, 09:58 PM
ampjunkielikeme's Avatar
GOT AMPS ?
0/11 ssssss381
Feedback Score: 17 reviews
Default [SOLD] Directed 600/4 Class A/B 4 CH Amplifier 125x4 [email protected]
1. Product: directed audio 600/4 4 channel amp
Dynamic Power Rating: 600 watts
S/N: > 95 dB
Freq. Range: 20-20kHz
Damping Factor: > 100
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 75 x 4
Rated Power @ 2 ohm: 125 x 4
Rated Power @ 1 ohm: N/A
Crossover: var. 12dB 2-way
Bass EQ: Yes 8 dB
RCA Output: Yes, stereo
Protection: T,S,D,R
*Dual power supplies for rock solid power
delivery under extreme conditions
Top-mounted controls easily accessed for
system tuning
*All models feature built-in high performance,
12dB/octave 2-way active crossovers
*Switchable 8 dB bass EQ function
T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
This is a Directed 600/4 4 channel amplifier. retail on this amp was around 400.00 when it was new.
it works 100%. i have bench/load tested it for a few hours with zero problems. i would rate it a 8.5 out of a 10 for cosmetics. it has a few scuffs and scratches, but nothing to hurt the performance. the power/speaker terminal screws are all there. its missing the little plastic cover for the gains.
you are going to get a true 75 watts x 4 rms @ 4ohms per channel with this amp. you will get even more -125x4 rms @2 ohm per channel....
it is built like a tank on the inside. dual power supplies . the amp could run a set of low power subs , or a couple sets of components. you will not be disappointed .
90.00 shipped to the cont usa
i will trade it for 2 used airbags. (re7. re6, firestone 2500, dominator 2500)
Directed Class D Amp krimro Wanting to Buy (WTB) 1 12-04-2011 07:41 PM
WTB/WTT [email protected] 4 ohm or [email protected] 2ohm amplifier Goindef154 Miscellaneous Stuff For Sale 1 04-28-2010 10:43 AM
Eclipse XA D-Class Mono Amplifier - New in Box 2whippets Mono Amplifiers 1 02-28-2010 11:16 PM
[SOLD] Memphis 16-MCA300 2 channel Class AB Full Range Amplifier! Shinju 2-Channel Amplifiers 6 02-28-2010 12:31 AM
F/S G&S GS6000 amplifier 1000 [email protected] ampjunkielikeme Mono Amplifiers 7 09-17-2008 10:18 PM
