Polk Audio 1100.5 All in One 5 Channel - Car Audio Classifieds!
Old 05-26-2010, 01:51 PM
fade2AQ's Avatar
Elite Bass
0/11 ssssss297
Default Polk Audio 1100.5 All in One 5 Channel
1. Product: Polk Audio 1100.5
Power Handling
  • 80W RMS x 4 + 280W RMS x [Mono] at 4 ohms
  • 125W RMS x 4 + 400W RMS x [Mono] at 2 ohms
  • 250W RMS x 2 [Bridged] at 4 ohms + 600W RMS x [Mono] at 1 ohm
Performance
  • 5-channel amplifier- enough for the entire system!
  • 125 watts x 4 (2 ohm) and 600 x 1 (1 ohm) continuous power; 250 x 4 (2 ohm) and 1200 x 1 (1 ohm) dynamic power. CEA-2006 Compliant specifications for true, accurate power ratings.
  • 2 ohm stable 4-channel operation and 1 ohm stable on mono subwoofer channel.
  • Super Efficient Class D Pulse-width modulation amplifier design.
  • High-speed MOSFET switching power supply and high current Bipolar Output Transistors pump maximum voltage and high current to your speakers or subwoofers.
  • Double Layer Fiberglass Epoxy Printed Circuit Boards for more rigidity, less shrinkage and a smaller overall amp footprint.
  • 6-Way Smart System Protection (SSP) circuits
Functionality
  • Fully adjustable 12 dB/octave high or low-pass crossover is also defeatable for full range (flat) operation (front and rear channels only).
  • Switchable 24 dB/octave subsonic filter protects ported subwoofers (subwoofer channel only).
  • Switchable 8 dB bass boost at 40Hz for extra bass thump.
  • Variable input gain optimizes match with different signal sources (250mv to 7.5V).
  • Mounting hardware with rubber isolation grommets and extra fuses included.
  • Light Bar/Fan Output- Connect an optional LED light bar or cooling fan for custom installations.
  • Multi-Color Status LED gives instant information on amplifier operation.
  • Remote Subwoofer Level Adjuster for subwoofer channel included.
  • RCA output (subwoofer channel only) for easy daisy chaining of other amplifiers.
3. Description/Condition: Perfect to a little dusty from my car.
I will not wipe it down. You can clean it if you like! I don't like scratches.
4. Price:
$325.00 plus shipping
Old 02-28-2011, 11:45 PM
Awaiting Confirmation
0/11 ssssss133
Any way this is still available?
WTT: Swiss Audio 2-Channel for powerful 4 Channel twistedchild420 Car Audio Trader (WTT) 6 02-15-2010 09:39 AM
Polk Audio SR 124/104 DVC sub. NinjaHanzo Wanting to Buy (WTB) 0 08-25-2009 06:28 PM
FT: Polk Audio DB650 grimreper912003 Car Audio Trader (WTT) 0 08-07-2009 02:55 PM
