[Pending]US Amps MD43 4ch - Car Audio Classifieds!
Old 06-21-2010, 11:11 AM
No, I'm not dead
0/11 sssss8128
Default [Pending]US Amps MD43 4ch
1. Product: US Amps MD43 Merlin 4ch
2. Specs: 100W x 4 @ 4O
150W x 4 @ 2O
300W x 2 @ 4O mono
Total Harmonic Distortion: 0.03
Frequency Response: 10~30K
Power Band Width (Frequency Response): 10Hz - 50 KHz
Crossover Frequency: 40~250 Hz - 15~40 dB
Damping Factor: 400
Dimensions: 2.5 x 10.5 x 19.75 Inches
Fuse Rating: 30A x 3
Power Voltage Range: 12~16V
High efficiency Class D design(1D/2D/3D)
Output stages utilize high-current MOSFET devices
High speed, audio-grade components in all low-level stages
Active Constant Current Bias Tracking Circuit
Platinum-plated RCA inputs and connectors
Wide range of sensitivity accepts signal from any head unit
24dB/octave Subsonic Crossover
24dB/octave Lowpass Crossover
True Line Output
Auto Bridge feature
Short Circuit Protection
Pretty under-rated.
3. Description/Condition: Mechanically 8/10: One output lug is stripped, easy fix which I can do or you can do, simply tap it to the next size up.
Cosmetically 8.5/10: The clear plexi panel under the amp is bowed on one end and the plastic housing for the speaker lugs has a small crack in it, not a break, just a crack and the black chrome on the ends is blotchy looking, the heatsink has a ding in one spot that's mostly hidden.
Electrically 9/10: It doesn't like being in a trunk on hot days. It'll function perfectly for an hour or better then shut down from thermal overload. If it is in a cool environment it does great.
4. Price: $200 shipped/insured
Old 06-21-2010, 02:48 PM
0/11 ssssss732
pm me a price picked up...any trades? (i'm local)
REFS: sold to audiobahnfan,Williambrea, jmsounds, Truckcap22k3n12ock here & several on CA.com under the same name
Old 06-23-2010, 12:25 PM
No, I'm not dead
0/11 sssss8128
Ttt
Old 06-23-2010, 03:50 PM
0/11 ssssss335
You looking for any trades or just cash?
Old 06-24-2010, 01:36 AM
No, I'm not dead
0/11 sssss8128
Depending upon what it is I'd consider a trade but I don't need subs, amps or coaxial speakers. That leaves comps, EQ/crossover combos & heads... on the latter it needs to have at least 4V pre-amp outs (6ch), onboard crossovers and a USB input.
Old 06-25-2010, 12:59 PM
No, I'm not dead
0/11 sssss8128
MD43 for cheap...
Old 06-26-2010, 02:12 PM
No, I'm not dead
0/11 sssss8128
Someone buy me....
Old 06-26-2010, 04:12 PM
0/11 sssssss34
when you say the plexi is bowed on one end, im trying to see what you mean by the photos but cant really tell..
but do you mean its pretty much caved in on one side? also the output set that is stripped are you talking about the head or the side wall that threads the screw?
haha thanks
Old 07-04-2010, 10:14 PM
No, I'm not dead
0/11 sssss8128
haha thanks
Look at the last pic, you can see the bow on the plexi at the daughter board.
Back up for sale and I'm going to fix the speaker lug Tuesday.
Edit: Speaker lug is fixed.
Old 07-06-2010, 11:57 AM
No, I'm not dead
0/11 sssss8128
Speaker lug is fixed, someone buy me.
I'll also trade for a 1500W bass amp.
[SOLD]US Amps MD43 A.I. James Multi-channel Amplifiers 11 09-22-2009 12:16 PM
[TRADED] Us amps MD43 F3M4 Multi-channel Amplifiers 13 08-12-2009 12:24 AM
my MD43 F3M4 General Car Audio Discussion & Questions 18 08-09-2009 08:25 PM
[PENDING] FS: IA 20.1 SPY Mono Amplifiers 9 08-06-2008 08:13 AM
