Sundown Audio 50.4 - Car Audio Classifieds!
Old 06-27-2010, 05:27 PM
0/11 sssssss25
Cool sold Sundown Audio 50.4
- Sundown Audio sax-50.4
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
12dB Octave Electronic Crossover Slope
Variable Subsonic Filter
Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Bass Boost Variable Control
Variable Bass-Boost Frequency Control
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Rated power output ----RMS power, 4 ohm stereo
50W x 4CH ----RMS power, 2 ohm stereo
80W x 4CH ----RMS power, 4 ohm bridged
160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4) High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) [email protected] Watts <0.1% Channel Separation 75dB Fuse Rating 25A x 2 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 310(L)mm
- This amp worked flawlessly when I removed it from my vehicle.
- Item has some scratches on top and bottom.
- No paperwork or wired remote
6.5/10 cosmetically 10/10 mechanically
$180.00 obo shipped to cont. U.S. 48 states willing to trade...just let me know what you have im always looking for something.
Old 06-27-2010, 05:28 PM
crownvic97's Avatar
Live. Life. Loud
0/11 sssss3620
Feedback Score: 35 reviews
are these under rated?
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
YGPM
Old 06-27-2010, 05:30 PM
0/11 sssssss25
yes they are and there tested at 12.8 volts i believe.
Old 06-27-2010, 05:34 PM
crownvic97's Avatar
Live. Life. Loud
0/11 sssss3620
any idea of what it does at 13.5-14v?
Old 06-27-2010, 05:39 PM
0/11 sssssss25
not sure but here is a test that was done on a sundown amp it might give u some insight. SAZ-1500D POWER TESTING - SSA Car Audio Forum
Old 06-27-2010, 05:53 PM
oxsign's Avatar
0/11 sssss1876
Interested in a ZX200.4 & ZX150.2?
Old 06-27-2010, 06:02 PM
0/11 sssssss25
sorry but no
Old 06-27-2010, 06:28 PM
0/11 ssssss513
trade for bnib rf 500.1?
Old 06-27-2010, 07:19 PM
0/11 ssssss857
pmed.
Sundown Audio SAE-1200D sundownz CACO Amp Internals 3 08-31-2012 05:12 PM
[NLL] (4) Sa-8's [Sundown Audio 8s] obrien202 Wanting to Buy (WTB) 2 04-30-2010 01:05 PM
spl box sundown audio z2 dosha (Sundown Audio) 8 04-09-2010 08:08 AM
Sundown Audio at SBN Derrick824 (Sundown Audio) 45 03-23-2010 08:43 AM
I want to buy sundown audio hell spl (db-r) 48 10-21-2009 09:10 PM
