[SOLD] JL Audio 500/5 Black Edition - Car Audio Classifieds!
Old 07-14-2010, 11:50 AM
0/11 sssssss10
Default [SOLD] JL Audio 500/5 Black Edition
ref's on diyma.com under same user name, pm with offers please
Used JL Audio 500/5 5-channel amp - black edition
* Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
* Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
* S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
* Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
* Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
* Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
* Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Differential-Balanced Input Topology: (3 pairs of inputs)
* Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
* Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (full-range or LP)
* Bass EQ: Variable boost up to 15db
* Infrasonic Filter: defeatable 24dB/octave at 30 Hz
* Left minus Right Ambience Circuit: ambient effect for rear channels
* Front and rear speaker output connections: accept up to 8ga. wire
* Dual mono subwoofer output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
* Dimensions: 19.7"L x 9.25"W x 2.36"H
Used condition, all the channels work perfect, has scratches on the top ( does not affect performance)
Inputs/outputs/control knobs, all in fantastic like new condition
$400 OBO shipped anywhere within the states will only accept PayPal
Price is very negotiable, so if you want to offer a lower amount,
ALL offers will be considered
Old 07-15-2010, 04:03 PM
0/11 sssssss10
Default SOLD
SOLD
[SOLD] NIB JL Audio 500/5 in rare all black finish from factory. SPANKYSPL Multi-channel Amplifiers 24 01-04-2010 09:16 AM
[SOLD] Orion Special Edition Charles Wieland RetroAudioInc Mono Amplifiers 0 10-03-2009 04:50 PM
[SOLD] Kicker Solobaric S12D Anniversary Edition MHD2000 12" Subwoofers 0 09-22-2009 11:13 PM
[SOLD] 2 Kove Special Edition 15"s A.I. James 15" Subwoofers 44 02-03-2009 11:54 AM
