w7 rebuild help?? - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Important CACO News > New Member Orientation
New Member Orientation Just introduce yourself and tell us about yourself.
Old 06-08-2011, 09:35 PM
Brand New Members
0/11 ssssssss0
Default w7 rebuild help??
im new to the form but been doing my research and i found that this site offers the most help but anyway i got a w7 that teampsi rebuilt the took the motor and mounted it on there 12inch basket and did a recone. well some metal shavings got up in the coil and after awhile it shorted out so im wondering. how hard it will be to tackle it myself to just recone it and how i can get the metal shavings off the magnets? any help would be much appreciated and if you got parts for the recone that would work let me no ill by them.
Old 06-08-2011, 09:37 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
contact PSI for parts
once u remove the soft parts take a popsicle stick and wrap tape around it (duct or masking) to get metal shavings. also a high pressure air can remove some depending on size of metal shavings
u need to figure out where the shavings came from so it doesnt happen again
TeamGG
Team D.O.A.
Old 06-08-2011, 09:39 PM
0/11 sssss3842
since PSI done the recone he should be able to build you a drop in for it.
And for the metal shavings....once you cut out all the old softparts use some compressed air to blow out what you can. If that doesnt get it all out try so tape folded around a playing card or something similar.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 06-08-2011, 09:42 PM
Brand New Members
0/11 ssssssss0
thanks for the quick reply. and is there any way to like incase the basket to prevent stuff from getting into the voice coil i would think the lower magnet would pick it up befor the inner magnet
Old 06-08-2011, 09:45 PM
Decaf's Avatar
0/11 sssss3460
u have to keep a clean car/box
i run my sub inverted and u can stick ur finger in the basket hole and touch the coil, just gotta be aware of things like sawdust and metal shavings
TeamGG
Team D.O.A.
Old 06-08-2011, 09:47 PM
Brand New Members
0/11 ssssssss0
yea good point def got to keep a clean area were your subs are. thanks again for the help.
sub rebuild bluthunder04 General Car Audio Discussion & Questions 5 10-25-2010 01:18 AM
Can anyone rebuild this? mytyeerinpie General Car Audio Discussion & Questions 55 09-11-2010 10:06 PM
Help Me Rebuild PLZ murderedtahoe General Car Audio Discussion & Questions 10 04-05-2010 01:41 PM
crx rebuild audiobuffru12 Build Logs 24 02-15-2010 07:38 PM
Want to do a rebuild... Andrew Enclosure Discussion & Design Construction Help 22 05-16-2009 10:42 PM
