"How to Install an Amp" Essay - Car Audio Classifieds!
Old 01-19-2013, 11:33 AM
Hdorre's Avatar
0/11 ssssss540
Default "How to Install an Amp" Essay
Alright.. so in English class, we need to write a process analysis essay to count as our midterm. The essay can be about anything that we're passionate about. The essay can be either directive or explanatory. I chose directive. The essay I decided on is "How to Install an Amp."
Here's what Im going to mention:
Power Input- Partially completes circuit. Mention wire size & its capacity. Also mention fuse size. Bring up consequences of running too small wire and fuse, along with a fuse too large. Mention voltage.
Ground- Partially completes circuit. Mention wire size & its capacity. Bring up acceptable grounding locations.
Remote Turn On- Tells the amp to turn on
Highpass (Subsonic) Filter- Only higher frequencies than set SSF play. Prevents damage to sub from playing too low frequencies. Mention bottoming out.
Lowpass Filter-
Only lower frequencies than LPF play. Prevents damage to sub from playing too high frequencies.
Input/Output RCAs- carries analog signal between HU & amps
Gain- matches amp input voltage with headunit output voltage. Go over RCAs briefly.
Phase- delays the signal being produced by the amp
Speaker Inputs- sends signal to actual speaker. Mention wire size.
Bass Knob- Can only reduce gain to reduce volume.
Can anybody add anything else worth mentioning?
Old 01-19-2013, 11:36 AM
Radioactiv's Avatar
0/11 sssss1311
If its not to far off talk about what the amp actually does? Most don't know they put out AC current.
Ranger Build
The Following 2 Users Say Thank You to Radioactiv For This Useful Post:
Austin175 (01-19-2013), Hdorre (01-19-2013)
Old 01-19-2013, 11:48 AM
Hdorre's Avatar
0/11 ssssss540
While thats true, Im not looking to get too technical. My English teacher is a female (not to be sexist), so I may as well speak Latin to her. I just dont want the essay to be too confusing. Ill try and mention AC current. If I cant pull it off well enough, Ill take it out.
Old 01-19-2013, 11:50 AM
Radioactiv's Avatar
0/11 sssss1311
I understand, its not hard to make peoples brain hurt. LOL
Ranger Build
Old 01-19-2013, 11:55 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Especially with car audio...
Sent from my SPH-D700 using Tapatalk 2
Old 01-19-2013, 12:01 PM
Austin175's Avatar
0/11 sssss4224
You could possibly add in what happens if you don't have the correct electrical to support or what can cause a amp to blow up.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
The Following User Says Thank You to Austin175 For This Useful Post:
Hdorre (01-20-2013)
Old 01-19-2013, 12:06 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
if you want to know what makes an amp blow up ask deanmachine. all of his blow up.
My game is legit,
Old 01-19-2013, 12:13 PM
Austin175's Avatar
0/11 sssss4224
Oh I know already from past experiences lol but that man must have bad luck if all of his blow or does he drive them to blow haha
(caco),
Old 01-19-2013, 12:19 PM
0/11 ssssss123
Don't forget the videos he posted. Wires everywhere, looked like an octopus.
The Following User Says Thank You to Soundedtrack For This Useful Post:
Old 01-19-2013, 04:13 PM
Hdorre's Avatar
0/11 ssssss540
Isnt that the truth?
Nice idea. When I talk about input voltage, Ill go over electrical.
15" TC Sounds Baskets, 10" spider landing, 3" & 4" coil, Never Used! zeuslicious Speaker Accessories & Parts 40 11-18-2012 01:58 AM
2-15" Ti Baskets, 10" spider landing, 3" & 4" coil, New Custom Colors and Never Used! zeuslicious Speaker Accessories & Parts 18 11-06-2011 06:53 PM
FS: 2-15" Ti Baskets, 10" spider landing, 3" & 4" coil, Custom color and Never Used!! zeuslicious Speaker Accessories & Parts 22 08-04-2011 12:08 AM
