Trying to fix electrical gremlin in concorde. - Car Audio Classifieds!
Old 04-15-2013, 10:19 AM
0/11 sssssss88
Default Trying to fix electrical gremlin in concorde.
Hello all, I have a 95 Chrysler Concorde with 3.5l engine. My problem is, when I turn on my wipers, I hear a click, and it kills power to my radio, and wipers will not come on. If I leave wipers on, usually after a minute or 2, the wipers will start to work, and radio comes back on. I recently replaced the multi switch (hi/low lights,wiper, and turn) in steering column, but the problem is still there. I tested different relays in the fuse box under hood also. Should I be checking into the wiper motor itself next? I also read about a body control module, but haven't been able to link it specifically to my problem. Any suggestions, ideas are greatly appreciated..
Old 04-15-2013, 10:27 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Wiper motor may have a short in it. If you have a DC clamp meter see what kind of current draw you have when it happens.
The Following User Says Thank You to audioarsonal For This Useful Post:
OldSchoolFosgate (04-15-2013)
Old 04-15-2013, 10:34 AM
0/11 sssssss88
I don't have a clamp meter. My dmm took a crap on me the other day too. Could I just run a wire from positive battery to the wiper motor to see if it comes on? I read somewhere that there could be corrosion on contacts to the wiper motor, so Im thinking of removing the whole assembly and tearing it down...
Old 04-15-2013, 03:08 PM
0/11 sssssss88
Update: So after working on it for a while. I got the motor to kick on after wiggling some wires right behind wiper motor. however, when I went to turn it to high speed, it would run but I could hear relay clicking and it would stop after a second or so.Thenkeep starting and stopping. Im wondering if the motor is going bad and drawing too much amperage?
Also after I worked on car for about 20 min with interior light on, I tried to start car and it just clicked. I charged the battery at 1.5 amp for 1 hour, then the car started right up.So I took my 3 yr old everstart battery to advance auto.They tested it with a big silver box with anolog display. After testing it with car off, and with car running(load test). He told me my battery was still in great shape.
how do i fix these jezus43130 General Car Audio Discussion & Questions 15 04-19-2012 10:09 AM
advanced electrical question on a/c electrical wire fatigue slowpoke General Car Audio Discussion & Questions 18 12-04-2011 01:40 AM
Is there any way to fix this More spl General Car Audio Discussion & Questions 6 03-31-2011 11:33 PM
how do I fix this? korey_hofer General Automotive Chat 16 04-01-2009 07:00 PM
How can i fix this? RollerDJ General Automotive Chat 15 02-12-2009 08:13 PM
