Belletire no help.. biggest tire size for 00 focus se wagon? - Car Audio Classifieds!
Old 05-21-2013, 02:34 PM
Racerkid15's Avatar
0/11 ssssss873
Default Belletire no help.. biggest tire size for 00 focus se wagon?
Found a good deal on a set of 17" wheels w/tires that I want but Belletire told me they (think) that the tire size 225-45-17 will rub the fender cause they are 1/2" taller then 215-45s.. if thats all it is then wouldn't the 215s rub everytime I hit a bump?
First time getting aftermarket wheels/tires so..
car is a 2000 ford focus wagon SE has 15" stock fords on it atm. anyone who has aftermarkets on their focus or knows of someone who fit these tires on would be of great help thanks.
2005 Dodge Magnum RT
4 Sundown Audio SA 15's, 1 Sundown SAZ4500 @ 0.5OHM Daily, 8 fosgate mids/highs w/ fosgate 400-4 amp. 152.9db @ 44 hrtz, 149.6db @ 22 hrtz sealed up legal on dash! Box 14.5 cu ft tuned @ 30 hrtz.
Old 05-21-2013, 05:45 PM
massivespl's Avatar
0/11 sssss8409
depends what your stock offset is and what the new rims offset is. need to know that and then go from there. also whats your stock tire size?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-21-2013, 05:55 PM
SUPER FAST SHIPPING
0/11 ssss31247
225 is ten centimeters wider than 215 [the 225 is the section width]
that's 5 centimeters on each side.. 3/16"ish inside and outside.
the 225/45 is .35" taller OD than the 215/45. not 1/2".. a little less than 3/8"
Tire Size Calculator - Discount Tire Direct
Old 05-21-2013, 11:39 PM
Racerkid15's Avatar
0/11 ssssss873
I'm being told by a friend they will fit cause they had 18s with tires a little bigger on their focus. also told the SVT Focus come with 17s factory.
Guess I'll buy em and hope for the best.. if they don't fit I can squeeze a size smaller of tread on em. thanks for the detailed message too sonic much appreciated!
Old 05-22-2013, 12:56 AM
ninos's Avatar
0/11 sssss2421
I dont have a wagon but i have a focus i have 18's on mine they dont rub 225 45 18's i think icant remember
Old 05-22-2013, 01:17 AM
0/11 sssss2011
Feedback Score: 61 reviews
i have an '00 Focus ZX3 on 19s 215/35, lowered 2". no rub.
Old 05-22-2013, 01:57 AM
younggunzbass01's Avatar
0/11 sssss1653
Check on the focus forums. Theyll have that info for you for sure.
Ginger Filternator Impala Wagon pt. 2
12 12's
10k
Build log here
Old 05-23-2013, 09:34 AM
0/11 sssssss51
I recall that the Focus SVT OEM tire size was 215/45/17. Folks around here with them used the 16" wheels from lesser Foci for their winter setups, for what little that is worth. Going with the SVT tire size will at least keep your rolling diameter close as possible and shouldn't mess up your speedometer/fuel economy/acceleration too much.
Biggest audio comp in IL and one of the biggest in the united states 9515ROB General Car Audio Discussion & Questions 0 09-13-2012 12:03 AM
Lo Pro Tire Help got160s? Off Topic Chat 3 10-14-2010 05:35 PM
Biggest tire bubble ever. Violence* Off Topic Chat 9 09-11-2010 09:55 PM
2001 Z71 tire size tater General Automotive Chat 4 03-22-2010 12:58 AM
2003 Focus wagon Bandpass willcann Build Logs 3 01-16-2010 10:49 AM
