Box build for a 15" TC 5200 - Car Audio Classifieds!
Old 09-25-2008, 07:39 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Default Box build for a 15" TC 5200
I'm building this box for my car, it will be the home to my 15" TC 5200.
It is 2.6 ft^3 tuned to 32hz, 43.5 in^2 of port
/ CAAA Member #2 /
Old 09-25-2008, 07:46 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
cant wait to see you drop the monster in
Old 09-26-2008, 07:14 PM
SPY SPY is offline
0/11 ssss10192
Update...
Done except for carpet and terminal.
You can see a small split on the front where the kerf starts. I dropped the beast on my leg before it was fully assembled and it started to split.
(so did my leg) and I didn't have enough wood to remake the whole piece so I just repaired it from the inside so it's solid. I was going to fill in the front but I got lazy, I may go back and do it later, we'll see how I like the box first.
Port and front are covered in spray on bed liner, the rest will be carpeted in a dark charcoal color. Amp should be here on Wednesday so the box will be done before then.
/ CAAA Member #2 /
Old 09-26-2008, 07:19 PM
xseveredveganx's Avatar
Chainsaw Squad
0/11 sssss3380
Nice!!!
Old 09-26-2008, 09:07 PM
0/11 sssss1123
Nice touch w the trim ring
Old 09-26-2008, 09:51 PM
SPY SPY is offline
0/11 ssss10192
Thanks, I actually wanted the sub to sit recessed a little but I didn't have enough height to put it on the face of the box. I decided I like the look of the recessed face though so I added the ring to push the sub out.
/ CAAA Member #2 /
Old 09-26-2008, 11:09 PM
0/11 sssss3638
that was quick
Old 10-01-2008, 08:49 AM
SPY SPY is offline
0/11 ssss10192
Box is carpeted, amp should be here today so hopefully everything will be installed by tomorrow.
I might try and clear coat the bed liner spray for more of a gloss finish.
/ CAAA Member #2 /
Old 10-02-2008, 05:35 PM
SPY SPY is offline
0/11 ssss10192
Installed the box today. It's a little tighter than I wanted (won't slide back as far as I planned) but I think it's because I removed the false floor and put the original floor back in.
Probably going to build a new box when my new amps get here.
/ CAAA Member #2 /
Old 10-02-2008, 06:20 PM
Loud Noises
0/11 sssss9731
how much would something like this cost?
[SOLD] Fs: 15'' tc-5200 q1.4 s Beatz 15" Subwoofers 5 01-24-2009 02:55 PM
Box build for 12" AQ HDC3 SPY Off Topic Chat 8 10-18-2008 12:03 AM
Box build for a 12" RE SE SPY Off Topic Chat 4 09-25-2008 08:12 PM
AQ HDC3 10" box build SPY Off Topic Chat 10 08-29-2008 03:23 PM
18" RD Alpha V1 box build SPY Off Topic Chat 9 08-21-2008 05:34 PM
