Car AC blower motor mods? - Car Audio Classifieds!
Old 08-09-2013, 11:59 AM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
Default Car AC blower motor mods?
I'm trying to increase my ac blower motor speeds. I Put in new Evaporator core, New blower motor, and also took my whole dash and ac duct work out to check for blockage. My ac get ice cold, but I have a 96 Tahoe And it does not have rear ac, to top it off my Tahoe is black with black interior! it takes forever to cool!!! I need more air volume! I'm considering going with 14V batts! before anyone mention tint My back windows are 100% black out and my front windows read 0% on the meter ( 2 layers of 5% and a layer of 20% on top of the 5%.
Old 08-09-2013, 01:20 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Put a window unit in the back.
Team CACO Team SHOK
Supporting Member
The Following 5 Users Say Thank You to 92K1500 For This Useful Post:
AQsrt4 (08-09-2013), bigdhenderson (08-09-2013), jockhater2 (08-09-2013), NEVERDONE (08-09-2013), profundus-sanus (08-09-2013)
Old 08-09-2013, 01:45 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
moving more air across the evap will not fix your problem,
it throws out the balance of incoming (return air/hot) an the volume of cooled air in the core itself, its factory matched
fan's cfm is matched to the surface area of the evap core
the compressor will never keep up unless you can figure out a way to run it on low speeds untill the cabin's temp is cold, then go to full speed pulling in cooler air
Old 08-09-2013, 03:19 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Moving more air wont cool as fast. The air will pass through the evaporator too fast and wont cool down as much before getting into the cabin of the vehicle.
The air is colder coming out the vents when you have it on low compared to high.
Team CACO Team SHOK
Supporting Member
Old 08-09-2013, 04:30 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Double up on everything. Compressor, core etc...
Current Build:
#60sHereIcome
Old 08-09-2013, 05:00 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
My game is legit,
Old 08-09-2013, 05:40 PM
sthrnbumpn's Avatar
0/11 sssss2961
thats a pretty clear explanation there, ^
not to get too techy on you guys..............
the extra volume of hot air is actually boiling the liquid refrigerant in the core alot quicker into gas,
when ever your self charging your personal A?C, you can usually put yor hand on the suction line at the exit of the evap, and you can tell when your core has enough liquid by a faint trace of cold in the line .
this is just one of many tricks of the trade
bottom line is find a donor vehicle (with rear A/C)
The Following User Says Thank You to sthrnbumpn For This Useful Post:
Old 08-09-2013, 06:02 PM
PapaGeno21's Avatar
0/11 ssssss448
I LOVE my rear AC in the suburban.
Truck turns into a freaking ice box.
03 Suburban
| Pioneer | FU Audio |
Rockville Audio | Crescendo | XS Power | SHCA & Knu | CDT | DC Power | Sundown | AudioTechnix |
Old 08-09-2013, 06:07 PM
sthrnbumpn's Avatar
0/11 sssss2961
gm's always have the best A/C systems, better than imports,
every gm ive owned can get down to 40 degrees at the vent, thats highly efficiant
Old 08-09-2013, 06:49 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
GM's are garbage when it comes to A/C. Most of the time they don't even work.
Last time I serviced my Nissan's A/C it was blowing 43*F at the farthest vent from the coil (drivers door) on full blast with the windows down.
And I haven't stuck a thermometer in my Ford but it blows ice cold too.
Team CACO Team SHOK
Supporting Member
Leaf-Blower Supercharging a 1978 Chevrolet Monza Spyder! - Roadkill rdooski3 Off Topic Chat 1 06-01-2013 11:07 PM
Cool your amps down..... 12V DC Blower fans "Squirrel Cage" ericcire Wiring, Electrical & Other Installation Equipment 6 02-26-2011 07:19 PM
Bought a new car!! Starting Mods this week!! TwistedMinds Off Topic Chat 70 10-01-2010 12:37 AM
SMART car w busa motor SPL Guru Off Topic Chat 8 10-09-2008 02:03 AM
