Box build for 2 RD alpha 10's - Car Audio Classifieds!
Old 08-07-2008, 08:51 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Default Box build for 2 RD alpha 10's
This one may take a while but should be nice when it's done.
2.57 ft^3 tuned to 34hz
/ CAAA Member #2 /
Old 08-08-2008, 08:25 AM
0/11 sssss9745
Default Re: Box build for 2 RD alpha 10's
I love those corners.
Old 08-08-2008, 08:43 AM
SPY SPY is offline
0/11 ssss10192
Yea, kerfed corners are nice. I did extra fine kerfs on this one to make the corners as smooth as possible. 18 cuts per corner
/ CAAA Member #2 /
Old 08-08-2008, 08:51 AM
0/11 sssss9745
Sweet !
Old 08-08-2008, 11:54 AM
SPY SPY is offline
0/11 ssss10192
2 more corners done.
One 96" piece of wood was not long enough to do it all so you will notice the joint in the last pic. it will be braced on the inside of the box and properly sealed to prevent any potential air leaks.
/ CAAA Member #2 /
Old 08-08-2008, 01:50 PM
waresgaragestereo's Avatar
Active Member
0/11 ssssss787
thats cool. how did u do those corners? i really like that idea and i seen it b4 but idk how to do it.
Zach Ware
Making things loud, its what I do.
DO NOT ORDER FROM AUTOPARTSGIANT.COM
Old 08-08-2008, 02:18 PM
SPY SPY is offline
0/11 ssss10192
It's called a kerf or kerfing. Most people use it to flair one or both sides of the port. This customer wanted all the corners kerfed so I thought it would be a good challenge.
There is a tutorial somewhere on the net. i will see if I can find it and post it up in the tutorial section.
/ CAAA Member #2 /
Old 08-08-2008, 02:19 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
put 12-18 small slits in the wood where the corner is desired Saw should be set at 5/8" if my memory serves me correct.
Old 08-08-2008, 02:30 PM
SPY SPY is offline
0/11 ssss10192
The # of cuts (slits) and space inbetween them varies with the size (diameter) of the corner and the width of your saw blade. 18 cuts is on the high side, usually closer to 10 cuts. 5/8" to 11/16" deep.
Once you get the hang of it it is very easy and looks very nice when finnished.
/ CAAA Member #2 /
Old 08-08-2008, 02:38 PM
0/11 sssss9745
I would love for someone to post that tutorial. Maybe I can learn something new.
3 10's or 2 12's Louder?? Blackout General Car Audio Discussion & Questions 19 11-11-2008 07:50 AM
Build for 2 RE SX 10's SPY Off Topic Chat 14 09-17-2008 10:01 PM
L7 10's tommyk90 10" Subwoofers 1 09-02-2008 11:39 PM
18" RD Alpha V1 box build SPY Off Topic Chat 9 08-21-2008 04:34 PM
