hinges problem - Car Audio Classifieds!
Old 03-26-2010, 10:02 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Default hinges problem
does ne one have any idea how to stop rear glass hinges on my explorer from breaking/ stripping, im on my third set and one just broke
its bad
http://www.youtube.com/watch?v=n2uNKmp5_gg
Old 03-26-2010, 10:16 PM
Lance_aka_64's Avatar
has too many subs
0/11 ssssss462
secure it with foam that is sticky on both sides? you dont really need to open your glass if you can open the hatch rite?
refs:
from here:teamsubgopoof, splvictim20, SundownAudioNY, goodstuff, Hertz5400LincolnLS, us3, bigjoker
from smd: RollinSoLow, Derrick824, Ray
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
Do what Sonic says, or be a man and punch her in the pussy.
Old 03-26-2010, 10:37 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
are you breaking the actual hinges on the top of the hatch or the window hinges?
i bent the hinges on the top of my hatch and actually ripped the mounts off the top of the hatch, but i've never broke the actual window mounts.. and i was doing well into 152's on music.
take a picture of broken ones for me?
Old 03-26-2010, 11:26 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
theres a hole in the glass and theres a screw that screws into the hinge that pinches the glass, i keep stripping the screws out over time. i tried loc-tite and it worked for about 6 months and it stripped back out today.
at 1:55 in the vid i can see the abuse they take
Old 03-26-2010, 11:27 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
i dont open either. i shot expanding foam in it and it lock up the latches
Old 03-26-2010, 11:47 PM
Veteran Member
0/11 sssss3026
get some serious 2 part epoxy and put that in the screw hole.. wont come out but it won't be able to strip out either.
have you adjusted your bottom latch at all?
Old 03-27-2010, 01:27 AM
Sonically_Sound's Avatar
http://www.betherave.com
0/11 sssss2125
I had this same problem in my sploder. I got roofing foam and lined the edges of the glass so it didn't , then like the guy said above I squirted the dual activation epoxy stuff in the screw holes and screwed them in.
Social:
Old 03-27-2010, 05:45 AM
0/11 sssss3164
wow i guess i was right about youve been beating on that door for a while lol. i knew it seemed more fuhkd up than usual
Old 03-27-2010, 06:16 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
huh? who is this?
ill take some pics of the stress points where its tearing the sheet metal
Old 03-27-2010, 06:18 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
no problems with the bottom latch just the hinges
sub problem RidnClean General Car Audio Discussion & Questions 11 02-15-2010 08:44 PM
Amp problem CTIPPINS General Car Audio Discussion & Questions 2 10-10-2009 11:39 PM
Need Some Help with this problem. RE_XXX General Car Audio Discussion & Questions 11 06-01-2009 09:07 PM
got a problem need help talon09 General Car Audio Discussion & Questions 19 04-13-2009 07:17 PM
Amp Problem RidnClean General Car Audio Discussion & Questions 10 09-20-2008 05:48 AM
