Box/center console request 1 10" nightshade - Car Audio Classifieds!
Old 05-16-2010, 10:58 AM
Prohibited Sellers/Buyers
0/11 sssss2890
Talking Box/center console request 1 10" nightshade
This is going to be used in a Chevy 2005 4 door to replace the center console.
17" tall x 13" wide, 22" deep front top curved nicely so there is no sharp edge kind of like kerfed port, sub bottom back, port top back 4" areo port hole I have the areo.. Just need to be able to install it. 10" nightshade, double baffled back, birch wood, inside fully fiber glassed and smoothed raw no carpet unless you can do vinyl and cloth I want it to look stock. If not I can get it done local.
As for the ports they will be outside the box and would just need to know the right lengths for 32hz, 38hz and 45hz so I can switch them out for comps etc..
Just let me know a price and when you can have it built.
Old 05-16-2010, 11:05 AM
0/11 sssss2890
1) Car- Year, Make, Model: Chevy 2500HD Quad cab
2) Subs- Make, Model, Size, How many: Sundown Nightshade 10"
3) Power- How much power per sub: 3000w 2 1500's strapped at 1ohm
4) Goal- SPL or SQ: SPL
5) Box type- Sealed, Ported, Bandpass, etc..: Ported
6) Sub/port direction: Back port back
7) Max dimensions: 17" tall x 13" wide, 22" deep
8) Desired NET vol and tuning:
9) Finnish-Paint, Carpet, Bare wood, etc... : Raw
10) Zip code for shipping Required for build only: 32807
11) Additional comments: See first post.
Old 05-17-2010, 08:02 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Do you have T/S specs or do you know the vol you want for it?
/ CAAA Member #2 /
Old 05-17-2010, 09:36 AM
0/11 sssss2890
yep.. The specs/size above is what I need the out side to be that can't change since its a console going between the seats and used as my arm rest. But double baffel the crap out of it I don't mind, stronger the better.
D2
1500w RMS
RE: 3.55 ohms
FS: 45.8 Hz
Qes: 0.366
Qms: 6.44
Qts: 0.346
Le: 3.25 mH
Vas: 5.97 L
BL: 23.69 N/A
Cms: 59.92 uM/N
Mms: 200g
Need help on a center console RetroAudioInc General Car Audio Discussion & Questions 15 02-07-2013 06:13 PM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 08:22 PM
"Old School" Nightshade Testing sundownz (Sundown Audio) 9 01-14-2010 07:47 AM
Mounting a sub in my center console tahoebrotha General Car Audio Discussion & Questions 10 12-29-2009 04:52 PM
center console amp rack designs/ideas? RE_Gawker Enclosure Discussion & Design Construction Help 7 10-06-2009 08:31 PM
