box build request - Car Audio Classifieds!
Old 05-18-2010, 12:12 PM
1/11 ssssss221
Default box build request
1. Car. Year, Make, Model: 2008 Scion Tc
2. Subs. Make, Model, Size, How many: Re Se 12" 2
3. Power. How much power per sub: 1500watts
4. Goal. SPL or SQ: SPL.. i wanna go low and loud
5. Sealed or ported: Ported
6. Sub/port placement:sub and port up firing
7. Max dimensions: 38w x 11.5h x 22L
8. Desired NET vol and tuning(optional): 4.0-4.6 cuft 31hz
9. Finish: carpet
10. Zip code for shipping: 33142
11) Additional comments:i prefer round ports, but a slot will do fine, unless another box design is suggested, last box i had flexed like there was no tomorrow, subs kept snapping screws so bracing would be great... and i am open to terminal options id like to keep my resistants as true as possible
Double baffle:yes
Double baffle/flush mount:
Round over all port edges inside and out: yes
Round over all outside edges:
45's in all inside corners:
Kerfed port: Yes if slot port is the route taken
Kerfed walls:
Slanted back:
Paint inside of port: yes, Yellow
Old 05-19-2010, 01:19 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
5.5-6 ft^3 net? that's a bit large for those subs, are you sure that's what you want?
/ CAAA Member #2 /
Old 05-19-2010, 08:44 PM
1/11 ssssss221
ive ploted it out on bass box pro and winsid and both show a nice gain at 40hz, these are recones se's with a beefier coil to take 1500 watts. the box i previously had was 4 cu ft @37hz, they played nice but i wanna tune lower 31 as stated. what are your recomendations spy? goal is to maybe get a hair trick with windows half open if that helps
thank you
Old 05-20-2010, 02:17 AM
SPY SPY is offline
0/11 ssss10192
thank you
The beefier coils will help but with too big of a box you will reach mech limits of the sub before then.
Do you have the T/S specs for the subs with new softparts?
/ CAAA Member #2 /
Old 05-20-2010, 12:47 PM
1/11 ssssss221
didnt get the t/s on the new softparts, but i was told that there pretty much same as the stock 12 spoke re se's, which Enter text here.is what ive been going by on winisd, and bass box pro
Old 05-25-2010, 12:37 PM
1/11 ssssss221
Spy,
took into account your bigger box bad for sub suggestion and reploted let me know what you think? also changed vol and max dimension on request
Old 07-06-2010, 09:41 AM
1/11 ssssss221
hey spy any word on this?
2 x AQ SDC2.5-12 box build request apbt55 Off Topic Chat 2 05-03-2010 02:05 PM
Box request for crownvic97 Can Anyone Build this?? crownvic97 Box Requests 3 04-29-2010 12:15 PM
AudioFreak Build Request AudioFreak Off Topic Chat 0 03-18-2010 01:17 PM
Box Build/price request Pieper Off Topic Chat 1 03-08-2010 11:05 PM
Box build request for jeres313 jeres313 Box Requests 7 03-07-2009 08:00 AM
