HELP. trucks messing up/overheating...BAD - Car Audio Classifieds!
Old 12-17-2008, 01:09 PM
0/11 sssss1418
Default HELP. trucks messing up/overheating...BAD
My truck decides to overheat extemely bad, I mean like pegged, I got it home, turned it off..steam just pouring out of the engine. I checked the coolant, coolant was fine, actually looked like the coolant didnt even move since I put some in. My dad and I checked the radiator, radiator was bone dry. We let it cool down and poured some water in, and as soon as we pour water in, it falls right out the bottom of the truck. So me and my dad thought it could be 4 things.
1) Blown radiator
2) bad water pump
3) blown head gasket.
4) A bad hose to the radiator.
Maybe one of you mechanics can help me out..
What does it sound like?
2005 Chevy Colorado
Pioneer Avic N1
Viper 791 XV Remote start/Security
PG RSD 6.5'" components
Kicker Hyperflex 0 Gauge
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
:CA.COM:memphisflex,iamamp3pimp, twistid, grimreper912003,Wkbdkid, csu87,1000101, mrwigglezdj,Goindef154
ROE: abmw735ie32, southpole1989, tacosys,Breakjunki, groundpound4200, Visitor
CAC.O: Caps, banginexplorer, tzsplfocus, jagblazer01, Mojo, lunari, Ctippins,duece212, derrick824, BlackWaterOP
Old 12-17-2008, 01:11 PM
0/11 sssss9745
I would say hose, 90% sure
Old 12-17-2008, 01:18 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
the engine is it leaking front, back, top, or bottom?
Old 12-17-2008, 01:21 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
Blown head gasket wouldnt leak that fast.
Old 12-17-2008, 01:23 PM
0/11 sssss1418
bottom kind of in the front..but yea. when it leaks. it pours.
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
98AckCL23's Avatar
0/11 sssss9929
sounds like the radiator, if you ask me... I had the same thing happen in my acura. I had a nice hole in the lower front of my radiator. after I got the new one, it was like a 15 minute fix... Although it could be the hose, I'd check those first.
From your last post, I'd definitely say check the radiator and hoses...
Old 12-17-2008, 01:24 PM
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
Sounds like lower hose or water pump seal.
Old 12-17-2008, 01:25 PM
0/11 sssss1418
alright, good thing radiators are easy to repair, and dont run that much either. I might just buy new hoses and a new radiator to be safe.
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 12-17-2008, 01:27 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
where exactly is the water coming from, that will give you your answer it sounds like
0/11 sssss1418
How can I get past the transfer case to see?
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
FS:(3) Traxxas Nitro Powered Trucks *Price Lowered* Parker G Miscellaneous Stuff For Sale 16 12-29-2008 08:10 AM
