SPY's 2 12" Isobaric build - Car Audio Classifieds!
Old 01-09-2009, 04:39 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Default SPY's 2 12" Isobaric build
OK, I finaly decided to build an isobaric enclosure for my 2 12" LMS-4000's
It should be finnished about this time next week, I hope
The main chamber is 1.5 ft^3 and the 2nd chamber should put the motor of the 2nd sub just out of range of the 1st sub at full xmax
/ CAAA Member #2 /
Old 01-09-2009, 04:40 PM
0/11 sssss1418
what makes it isobaric?
2005 Chevy Colorado
Pioneer Avic N1
Viper 791 XV Remote start/Security
PG RSD 6.5'" components
Kicker Hyperflex 0 Gauge
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
:CA.COM:memphisflex,iamamp3pimp, twistid, grimreper912003,Wkbdkid, csu87,1000101, mrwigglezdj,Goindef154
ROE: abmw735ie32, southpole1989, tacosys,Breakjunki, groundpound4200, Visitor
CAC.O: Caps, banginexplorer, tzsplfocus, jagblazer01, Mojo, lunari, Ctippins,duece212, derrick824, BlackWaterOP
Old 01-09-2009, 04:42 PM
SPY SPY is offline
0/11 ssss10192
you will understand once I get more done.
/ CAAA Member #2 /
Old 01-09-2009, 04:52 PM
Stuckinok's Avatar
Active Member
0/11 ssssss502
sex....
2005 TOYOTA TACO TRD OFF ROAD
System REBUILT watch the build log.
CAAA Member #5
Old 01-09-2009, 04:53 PM
0/11 sssss1418
is it ported rear chamber and ported front chamber..sealed rear ported front, vice versa? or none of it at all
is isobaric like bandpass?
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 01-09-2009, 04:55 PM
SPY SPY is offline
0/11 ssss10192
It's 2 sealed chambers.
The sub in the first chamber fires into the 2nd chamber, the sub in the 2nd chamber fires out.
/ CAAA Member #2 /
Old 01-09-2009, 05:07 PM
0/11 sssss1418
confusing..i guess i will figure it out when you build it.
2005 Chevy Colorado
Pioneer Avic N1
2 Kinetik HC600
1 MOJO 15"
7 cu. ft 32 hz.
Refs
Old 01-09-2009, 05:12 PM
xseveredveganx's Avatar
Chainsaw Squad
0/11 sssss3380
Isobaric's are, well, different...
Any particular reason you decided isobaric? Just something to try? I'm really curious how it turns out!
More pics!
Old 01-09-2009, 05:19 PM
Anotherguy's Avatar
Active Member
0/11 ssssss605
Why are you building and isobaric enclosure? Back in the day they were a little more common when subs had lower power handling and lower motor force. They aren't necessary anymore with higher power handling.
Don't take me the wrong way, just wondering your want is for this type enclosure.
________
Honda Cb250Rs Specifications
Old 01-09-2009, 06:01 PM
SPY SPY is offline
0/11 ssss10192
I decided on the isobaric setup due to space issues and because I've wanted to try one since I saw my first one about 12yrs ago.
TC lists the sealed box requirements for the 12" LMS-4000's at 3.0 each, I could have run one in the space I wanted to use but I really wanted to run both. There was no way I could fit 6.0 + displacement in my car so I decided it was the perfect opportunity to give it a try.
If I don't like it I'll just build a different box for one of my other subs, hell even if I do like it I'll still build something else just because I like to try new stuff.
/ CAAA Member #2 /
2 15" MT's build!!! rdaudioman1256 Build Logs 24 01-11-2009 01:20 PM
Box build for 12" AQ HDC3 SPY Off Topic Chat 8 10-17-2008 11:03 PM
Box build for 2 10" TC OEM's SPY Off Topic Chat 5 09-26-2008 11:33 PM
Box build for a 12" RE SE SPY Off Topic Chat 4 09-25-2008 07:12 PM
18" RD Alpha V1 box build SPY Off Topic Chat 9 08-21-2008 04:34 PM
