4th Order design and build quote - Car Audio Classifieds!
Old 06-01-2011, 04:36 PM
0/11 sssssss59
Default 4th Order design and build quote
1) Car- 2007 Mazda 6i Sedan
2) Subs- Two 12in PSI
3) Power- 1500watt Each
4) Goal-SPL, but a no comp/burps...
5) Box type- 4th order ported through rear deck or ski hole (both require cutting and decision would be based on input from you/others)
6) Sub/port direction:
7) Max dimensions: 43 x 15.5 x 21 is max dimensions but would require some notching to be done. Ideal dimensions is something on the order of 40 x 15.5 x 18 but depth (18) can be increased if necessary.
8) Desired NET vol and tuning: I have no idea, I turn to the box design gurus for this. I know that David had stated 1.5cu ported and 1.0 sealed when I originally ordered the first, but I don't know if that equates to 4th order as well.
9) Finnish-carpet, but depending upon price/ease because of it being bandpass style.
10) Zip code for shipping Required for build only: 55362
11) Additional comments: I am pretty open on this build to whatever your artistic hear desires . I just want to get rid of the nasty trunk rattles, it was bad enough with just one, but now I am going to have a second I don't think I'd be able to handle it.
I am looking for a design and build quote both, as well as lead time to complete it. I don't have a lot of information on the subs as far as specs go, I am going to pm David and see if he will chime in with some input.
I am open to any suggestions you may have as well. It doesn't have to look pretty since it's only in the trunk, but at the same time I might like it to, if my budget will allow.
Thanks,
Matt
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
Box design/quote nyoc2020 Off Topic Chat 1 04-14-2011 02:15 AM
box design quote/idea mbdblue Off Topic Chat 0 02-23-2011 03:53 PM
Price Quote / Order Biggy (Fix My Speaker) 1 06-02-2009 08:09 AM
