Passive Radiator info - Car Audio Classifieds!
Old 06-18-2012, 01:16 PM
99Bonney's Avatar
0/11 sssss6246
Not sure if it should be here or in your FMS section but I was inquiring about the use of a 10/12" PR in conjunction with a 10" sub. Box is 1 cube net sealed right now. Buddy wants to either port it or try out a PR. You said a 12" PR would do well 1cft. Down the road if he want to enlarge the box a bit and add another 10, would the 12" PR still be sufficient or will I need another PR. Let me know what you think, thanks!
Still interested!
I'd like to know some info before I have to order a 3" aero for my buddy. Thanks
I know, ordered from him in the past. Just a little urgent.
Bump!
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 06-20-2012, 09:04 AM
0/11 ssssss147
you gotta be patient man dave is busy. it took him a week for me and him to get in touch with each other. he isnt ignoring you.
Old 06-22-2012, 09:34 AM
TeamPSI's Avatar
0/11 sssss4041
Still interested!
Bump!
Dropping a 12" PR into the 1ft box would be a great setup with the single 10" sub.
Would it work with (2) 10's and a single 12" PR?
YES, but you would be limited by the PR itself. You'd be able to max out the PR in high power/high excursion situations. You'd basically outdisplace it, and over-excurt it.
You'd still want to add another PR to keep things working properly.
-David Moore
Old 06-22-2012, 12:25 PM
99Bonney's Avatar
0/11 sssss6246
Is there any general rule of thumb for PR size vs enclosure size? For example would 2 10" subs work well with 2 10" PRs? Or is 1 10" PR good for .5cft and 1 12" for 1cft? Some info on that would be greatly appreciated.
2006 Tahoe
Amps-Crossfire 8k
Old 06-22-2012, 01:03 PM
0/11 ssssss345
No. You want to choose the PR size based on the size and excursion of the driver. You want about 50% swept volume of the PR compared to the active driver.
You tune the PR by changing the weight. It's the same concept as lengthening the port of a ported sub. Let's say you have a 10" PR with an Sd of 310cm^2. That's the same as a port that has 310 cm^2 of opening (round, square or slot - it does not matter). Then use your standard modeling software to determine how long the port needs to be to get the turning you want. Then you convert that column of air to grams and that is needs to be the moving mass of the PR.
Or you download Unibox and use the PR box design section.
Old 06-22-2012, 01:17 PM
99Bonney's Avatar
0/11 sssss6246
Thank you for the info! Now time to apply it lol. I'll look into getting that unibox program.
2006 Tahoe
Amps-Crossfire 8k
Old 06-22-2012, 01:44 PM
0/11 ssssss345
Unibox - Unified Box Modeler Loudspeaker Design Software
Old 06-22-2012, 02:40 PM
99Bonney's Avatar
0/11 sssss6246
Downloaded. Maybe you could walk me through modeling PR's? Theres an overwhelming amount of info on this spreadsheet lol.
2006 Tahoe
Amps-Crossfire 8k
Old 06-22-2012, 02:56 PM
0/11 ssssss345
If you can't get the information for the PR, just model a ported box using round ports. If you have a 10", then find the moving diameter from the Sd of the PR. Once you do that, you have the diameter of the port. Your port will be extremely long though. Once you figure that out, find the volume of air inside the port. From a physics site, 1 cubic foot of air at standard temperature and pressure assuming average composition weighs approximately 0.0807 lbs. Convert that to grams and that's the moving mass of the PR.
Another way to figure this out is to mount the PR backwards so you add/remove weight. The resonant frequency of the PR is your tuning frequency. You can determine that by playing a sine wave sweep and seeing at which frequency it moves the most. Or you can use Woofer Tester (I recommend that to anyone building subs) to quickly find not only the enclosure's Fs, but you can find your impedance rise as well.
Old 06-22-2012, 03:53 PM
99Bonney's Avatar
0/11 sssss6246
Thanks for the reply. You make it sound simple lol. I think ordering woofer tester might be a good idea. If I gave you the dims of the enclosure and model of 10" sub do you think you could model it up close enough even without the PR's specs? Do you even need actual dimensions or is the amount of airspace all that is relevant?
2006 Tahoe
Amps-Crossfire 8k
passive radiator timwebb General Car Audio Discussion & Questions 4 04-12-2012 09:05 PM
passive radiator richdog102 (Fix My Speaker) 2 02-07-2012 12:53 PM
Passive Radiator jwright0291 Wiring, Electrical & Other Installation Equipment 6 02-05-2012 10:29 PM
passive radiator basschild Speaker Accessories & Parts 0 05-17-2011 04:09 PM
Passive radiator? basshead08 General Car Audio Discussion & Questions 0 03-02-2010 08:27 AM
