Psi Platform 2 compared to Audioque - Car Audio Classifieds!
Old 09-13-2012, 01:57 PM
0/11 sssssss64
Default Psi Platform 2 compared to Audioque
i was wondering, how does the psi platform 2 compare to Audioque's HDC3?
would it produce higher amounts of spl? better SQ? and would it be a better daily driver?
Old 09-15-2012, 12:56 PM
TeamPSI's Avatar
0/11 sssss4041
Any of those questions can all be answered by "It all depends".
We build our subwoofers specifically for the install that they are to be used in. By doing this, we guarantee the sub's optimal performance for the customer.
Do I think that I standard Platform 2 will beat the HDC3 in every way, in every install? No way.
Do I think that we could make you as happy, or happier, with our subwoofer as opposed to buying an HDC3?
Absolutely!!!!!!
If you'd like for us to give you a recommendation or quote for a subwoofer, just supply some basic info about what you want.
How many subwoofers do you need?
What size do they need to be?
How much power does EACH subwoofer need to handle? (RMS power)
The brand AND model of amplifier you'll use with it?
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?)
Is it for competitions only?
Where are you located?
If you have any questions, just let us know.
Thanks,
PSI Car Audio
-David Moore
Old 10-20-2012, 02:23 PM
0/11 ssssss772
Default blown mmats 15s
i have pair blow mmats 15 subs so im not sure what size or etc recone i could get to replace them with so any suggestions or ideas would be great thanks
Old 10-29-2012, 12:53 AM
0/11 ssssss462
I'd go.with the psi subs
The Following User Says Thank You to akmarcos12gauge For This Useful Post:
TeamPSI (10-29-2012)
Psi Platform 2 or Audioque HDC3 fletch745 General Car Audio Discussion & Questions 4 09-13-2012 12:07 AM
PSI Platform 2 brandon_s0854 General Car Audio Discussion & Questions 1 06-20-2012 10:34 AM
Psi platform 2 ItsAjeepThingg General Car Audio Discussion & Questions 5 02-29-2012 04:10 PM
MTX RFL15 Vs PSI platform 3 15? MtxNeonguy937 General Car Audio Discussion & Questions 2 07-23-2011 03:47 PM
psi platform 12 who has one , i want a review burzendowski (PSI Car Audio) 18 10-07-2010 08:38 PM
