Looking for suggestions on some PSI passive radiators - Car Audio Classifieds!
Old 10-19-2012, 06:29 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default Looking for suggestions on some PSI passive radiators
Long time no poast!
It's time to change my HT system and I'm buying the two 15" PR's that you built for mytye awhile ago to go with my proto 18" RL-p. Sound Splinter says 7ft^3, but to me, 7 cubes sounds like way to much for a sealed box. So, what do you suggest for size, and what kind of weight, if any, should I add to the PR's?
Proud Member of CAAA!
Old 10-19-2012, 06:44 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
id keep adding as you test until you get the response your looking for
Old 10-19-2012, 06:47 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
That would work for weight, but how bout the size of the enclosure?
Old 10-23-2012, 01:47 AM
TeamPSI's Avatar
0/11 sssss4041
7ft wouldn't be too bad for HT use.
Do you plan on playing music much, or is it strictly for movies/TV?
How loud do you really want it?
How much power do you have?
Any clue of where you'd like it tuned? Most HT subs are tuned from 15-25hz. My personal HT setup is 8ft @ 18hz (I would change to ~24-25 if I could) with (4) 18" PR's and (2) Platform 1 15's.
If you want killer rumble from your HT setup, use 6-7ft and tune to 20-25hz.
-David Moore
TeamPSI's Avatar
0/11 sssss4041
And welcome back!
-David Moore
Old 10-24-2012, 11:08 AM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
This is used almost 50/50 for music and movies, so something good mix would be good. Right now I have about 850wrms on tap to drive that woofer, which is just about right for that sub. My current setup is in a T-line tuned to 21hz IIRC. Been quiet a few years since I've build it and I'm looking to kinda keep a same responce, but not take up 21 some odd cubic feet.
Old 10-24-2012, 11:33 AM
TeamPSI's Avatar
0/11 sssss4041
I would go ahead with 6-7ft @ 25hz then!
-David Moore
passive radiators davidt487 General Car Audio Discussion & Questions 0 01-31-2012 09:58 PM
Anyone interested in Passive Radiators?! TeamPSI (PSI Car Audio) 253 05-23-2010 01:16 PM
15" Passive Radiators scottiej Speaker Accessories & Parts 2 11-30-2009 11:39 PM
Passive Radiators: The Basics madmat Tutorials & Quick References 0 10-28-2009 08:22 PM
[MODERATE] Passive Radiators danteBirosel Tutorials & Quick References 0 11-12-2008 03:10 PM
