DARC audio Nightshade Psi beast - Car Audio Classifieds!
Old 10-19-2012, 11:03 PM
Darcaudio17's Avatar
0/11 ssssss325
Default DARC audio Nightshade Psi beast
subs
2 18s Sundown nightshade v1s with 2k psi soft parts (direct 8 awg leads, quad spiders, 8 layer coil)
the newest port
power
on a single aq2200 for now... waiting for the other
NUMBERS
149.0 @ 39 on music
148.6 @ 34 on tones
both door open on dash
SUBS: 6 ia dp 12s
SUB AMP: 1 IA 40.1
HIGHS: 8 apmb 6s and 4 tw44 tweets
HIGHS AMP: nendo 1kc4
BATTS: up in the air
ALT: 320a Tenney alt
The Following 2 Users Say Thank You to Darcaudio17 For This Useful Post:
sundownz (10-23-2012), TeamPSI (10-23-2012)
Old 10-23-2012, 01:48 AM
TeamPSI's Avatar
0/11 sssss4041
Wow, very nice man!
-David Moore
Old 10-23-2012, 02:12 AM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
looks serious. Videos!
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 10-23-2012, 07:38 AM
0/11 ssssss325
Couple look up both my channels on YouTube
Titanshockey17 and darcaudio17
Both channels should have plenty of vids from both my current and past setups
Enjoy and feel free to lmk what you think
Old 10-23-2012, 07:39 AM
0/11 ssssss325
Originally Posted by TeamPSI View Post
Wow, very nice man!
Thanks
Psi ftmfw
IM trying my hardest to get a 50 of just the single 2200 so stay tuned for some better numbers
Old 10-23-2012, 04:45 PM
0/11 ssssss345
I've never gotten a definitive answer about picture number 2. The mounting screws are pushing down the gasket material. Is that bad for the driver?
Old 10-23-2012, 04:49 PM
0/11 ssssss325
you are right, but not really bad for the sub, just a bad seal because it wasnt down as tight at possible, ive recently switched it to where the bolts are now hidden tucked under the gasket
SUBS: 6 ia dp 12s
SUB AMP: 1 IA 40.1
Old 10-23-2012, 04:50 PM
0/11 ssssss345
That's what I assumed. But with David in the thread, I was hoping he would chime in with his expertise.
Old 10-23-2012, 05:01 PM
0/11 ssssss325
NOT enough thanks can go out to psi/fixmyspeaker for getting these woofers pounding
not to shabby for my first couple recones
SUBS: 6 ia dp 12s
SUB AMP: 1 IA 40.1
Old 10-24-2012, 11:41 AM
TeamPSI's Avatar
0/11 sssss4041
You definitely want the screws/bolts to be under the gasket, directly on top of the frame. Screws or washers over the rubber gasket will not seal or secure the sub properly.
-David Moore
DARC AUDIO STANG 4th ORDER Darcaudio17 Build Logs 69 01-02-2013 10:26 AM
PSI/Audiobahn beast 1ndatrunk 15" Subwoofers 18 01-23-2012 03:46 PM
PSi/Nightshade 18 @ .5ohm on Bc2000d IS300IAdeathRow Car Audio Videos 11 01-01-2012 06:52 PM
Psi beast jusBloud 15" Subwoofers 38 06-01-2011 07:16 AM
[TRADED] PSI Custom BTL, 3000+ rms, black and white beast mode Wheres The Butta 15" Subwoofers 23 09-19-2010 01:20 PM
