Mark's (2) Platform 2 series 15's - Car Audio Classifieds!
Old 11-01-2012, 12:10 AM
TeamPSI's Avatar
0/11 sssss4041
Default Mark's (2) Platform 2 series 15's
$295 each
-David Moore
Old 11-21-2012, 10:11 AM
Brand New Members
0/11 ssssssss1
What's the rms on these and fs and xmax
Old 11-27-2012, 09:32 PM
TeamPSI's Avatar
0/11 sssss4041
The Platform 2 Series is a very well-rounded daily usage subwoofer. This subwoofer offers the utmost in sound quality, while also being able to handle large amounts of power.
The Platform 2 retains the same mounting depth of our smaller Platform 1 Series, while power handling and output are both increased tremendously.
Power Handling Ratings:
RMS Power - 1500 watts
Peak Power Handling - 3000 watts
Standard features include:
Dual stacked 7.5" x 1" Y35 ceramic slugs
Chrome top and bottom plates
FEA optimized motor assembly
8 spoke aluminum cast frame - Black
Chrome push terminals
Extended length 4 layer aluminum roundwire voice coil
Dual 1 and Dual 2 ohm standard impedances
Dual 8" progressive roll poly-cotton spiders
Sewn 3mm heavy duty leadwire
Kevlar impregnated pulp cone body
1.5" wide roll rubberized foam surround
6" polypropylene dome dustcap
PSI logo
Enclosure Recommendations:
Sealed - 1.5-3.25 ft^3
Ported - 3.5-5.5 ft^3
This product may also be used in Infinite Baffle and Bandpass applicaitions. Please contact us before purchasing this product for these installations.
T/S Parameters for standard Platform 2 15":
Revc = 3.4 ohms
Fms = 25.8 Hz
Qes = 0.62
Qms = 2.97
Qts = 0.51
Sd = 823cm^2
Vas = 120.3 L
BL = 15.5
Mms = 290.3 g
Sensitivity = 88.86 dB @1W/1m
Sensitivity = 90.4626 dB @2.83Vrms/1m
Xmax = 56mm total
Usable Excursion = 3" total
Product Dimensions:
Overall diameter - 15.5" w/ gasket
Cutout Diameter - 14.125"
Mounting Depth - 8"
Displacement in enclosure - .16 ft^3
Weight - 38 lbs
-David Moore
Ronnie's (2) Platform 1 series 12's TeamPSI (PSI Car Audio) 0 10-31-2012 11:48 PM
Platform 2 series 18" for Tanner TeamPSI (PSI Car Audio) 0 10-31-2012 10:13 PM
Stewart's (2) Platform 1 15's TeamPSI (PSI Car Audio) 0 02-29-2012 07:42 PM
(2) Platform 3 15's for BassHeadsEnt! TeamPSI (PSI Car Audio) 10 02-07-2012 11:08 AM
Brandon's Platform 2 15's TeamPSI (PSI Car Audio) 0 08-22-2011 05:28 PM
