Quick question about the platform 1 subs - Car Audio Classifieds!
Old 02-14-2013, 10:02 PM
VVVVVVVVVVVVVVVVVVVVVV
0/11 ssssss134
Default Quick question about the platform 1 subs
Looking to get into a platform 1 18. I am interested in the high power upgrade that offers a longer voice coil. I need to know what the coil does to the xmax and total excursion of the subwoofer. Anyone who actually knows this info is welcome to answer, I understand the owner is busy.
Thanks
Old 02-15-2013, 09:35 AM
TeamPSI's Avatar
0/11 sssss4041
The longer coil adds xmax (and total excursion capability) and adds power handling.
-David Moore
Old 02-15-2013, 09:55 AM
0/11 ssssss134
Thanks, I know that part. I'm wondering how much it adds.
'08 Dodge Dakota Crew Cab
Head:Clarion vz401--Mids: Diamond D9-71 component set--Sub: Team PSI platform 2 18"d4 in 4 cu.ft--Amps: Soundstream REF 4.760, Hifonics BXI2610d @ 2ohms(1700 rms)
refs-CA-F: Spooney, mj-tc, Cleansoundz, rc10mike, kmanian, cozce, Spy, ewoevo, stylez12321, stirfri4202,nihl8ion--SSA: sundownz, [email protected], BKOLFO4 --DIYMA: lashlee, nigel1977, Ibizonacid--Here: snyderd758
Old 02-16-2013, 01:19 PM
TeamPSI's Avatar
0/11 sssss4041
Oh, ok.
The standard coil in the PF1 18" would be about 45mm long. The high performance coil would be about 60mm long.
Depending on how you feel like calculating xmax, this would add about 15-18mm total xmax.. which is a lot of displacement on an 18" sub especially.
Edit:
Also, if you are just looking to maximize the xmax for a special purpose, we can actually squeak a little more out of it.
-David Moore
Old 02-16-2013, 01:22 PM
0/11 ssssss134
Oh, ok.
Edit:
Wow, so with the extended coil the total xmax is 70+mm?? Sold lol.
I'll be getting one once my taxes come back around the end of the month.
Thanks
Edit: no real special purpose, just want to get as much displacement out of it as possible and still work well off 1000 watts.
Old 02-16-2013, 02:18 PM
TeamPSI's Avatar
0/11 sssss4041
I feel like I should clarify more for you. No, the high performance coil wouldnt increase xmax to 70+mm.
The 56mm listed on our site is actually a little less than what would be calculated up when using the longer coil. A real measurement would probably show more, but instead of overestimating, it is listed at a little less.
To be honest, 95% of PF1 18" sales have all been with the longer high performance coils, so I chose to list the xmax at what most people would have.
Xmax with the shorter, standard coil would be about 34mm total.
I would urge you to not worry all that much about just one spec though, unless, as I said, it was for a special purpose. There are drawbacks and compromises to be made in every aspect of making a subwoofer, so adding xmax can hurt you in other ways.
As I said, most PF1 18" users are getting the longer flatwound coil. It is worth it!
-David Moore
The Following User Says Thank You to TeamPSI For This Useful Post:
Mr.G6 (02-16-2013)
Old 02-16-2013, 02:28 PM
Mr.G6's Avatar
0/11 sssss4614
very well said..
and this is why ive gotten many psi reconed woofers
2000 Gmc Sonoma ext cab
Old 02-17-2013, 06:39 PM
0/11 ssssss134
How would I go about getting a little more info on the tradeoffs involved with this? I am interested in maximizing the 1 kwatt I have available to me, not for an spl comp, just for personal listening. I love to hear/feel when my sub gets down in the 20hz range with authority. I had an Ascendant Audio Havoc 18 a few years ago that was just sick in 4 cubes sealed, and I decided to get one of those again, until I saw your platform 1 subs and the price got my attention. So, I guess what I want is a sub that gets me the most displacement in around 4-5 cubes sealed. I can still get the Havoc again, but am not interested in spending the $420+ that it takes to get one new. Any help would be appreciated.
Thanks
Old 02-17-2013, 09:02 PM
TeamPSI's Avatar
0/11 sssss4041
I think that the Havoc that you had a while ago is smaller than what they sell as the Havoc now. I could also be completely wrong.
As concerned as you are with performance, you want to at least pt for a voice coil that can handle the power that you want to use. Not going with the high performance setup, or other beefier coil ,would be a waste of time.
In your case, I would actually recommend a Platform 2 series 18", custom built with an extended length copper voice coil. That will really shake the ground with 1000w rms! It's more than a Platform 1, but not that much. By the numbers, it doesn't get you more displacement, but it does have a lot more strength.
If you can't quite swing the price difference, the Platform 1 18" with the same copper coil would be the 2nd best pick. It would sound boomier and have less authority than the PF2 though.
-David Moore
Old 02-17-2013, 10:41 PM
0/11 ssssss134
Is that the high performance option for the pf2 or is it a custom job beyond that? If it is more custom, can you give me a price for it?
Thanks
quick Question about inverted subs crackills General Car Audio Discussion & Questions 5 06-12-2012 11:49 AM
probably a dumb question but quick question about pollyfill mattintc10 General Car Audio Discussion & Questions 15 05-05-2012 05:46 PM
quick question need quick answer 05xxx perfect_prefect General Car Audio Discussion & Questions 0 01-25-2011 03:44 PM
Quick question on deal on DD subs ?? Help worstenemy453 General Car Audio Discussion & Questions 19 10-19-2009 04:45 PM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 08:41 PM
