DD 9512 G Recone - Car Audio Classifieds!
Old 02-26-2014, 07:34 PM
0/11 sssssss25
Default DD 9512 G Recone
I was wondering if its possible to create a recone that is a monster on the lows and still be able to take 5k (On a pair of 12s)? I am coming from a FI Sp4 15, to 2 DD 9500 12s, and just want it to still kill lows, and be able to take power.If not, how much power could i get the pair made to handle and stil get low
Old 02-27-2014, 12:41 PM
TeamPSI's Avatar
0/11 sssss4041
The small coil is the limitation in a DD 9500. If you want them to be relibale, not scrape and scrub the coils and sound good, the power cap would be around 1800-2000w rms per sub m with burps or musical peaks above this amount being ok. You would just want to be sure not to overheat the coils.
They are a small gap/coil by design and we can only change them by machining the motor, which adds a lot of cost.
We do offer the best recones for these for SQ and low end output while still being abuse resistant and loud at the same time. We use flatwound aluminum coils, increased spider size of 8", sewn leadwire, and HD pulp cones with wide surrounds for increased excursion capability.
-David Moore
Dd 9512 g nater 12" Subwoofers 47 04-30-2014 04:46 AM
4 dd 9512 Beatnoutdaframe 12" Subwoofers 7 07-13-2012 10:44 AM
2 dd 9512 assassin1840 12" Subwoofers 37 02-13-2012 09:04 AM
Dd 9512 Beatnoutdaframe 12" Subwoofers 3 10-25-2011 10:46 PM
Dd 9512 thepolicerhere (Fix My Speaker) 1 09-08-2011 12:37 PM
