RE XXX v3, or pre 05 - Car Audio Classifieds!
Old 07-27-2014, 09:17 PM
0/11 ssssss586
Default RE XXX v3, or pre 05
I'm posting this here because REaudio wouldn't know.
David, you designed the 02-03 and 04-05 RE XXX.
Can I run the 02-03 XXX(with the flat bottom plate) and the 04-05 XXX(with rounded bottom plate) - together with the same soft parts and be ok? I see the t/s specs are off, but I'm guessing they used different soft parts.
Any answers will be greatly appreciated.
Old 07-27-2014, 11:41 PM
0/11 sssss1217
Feedback Score: 40 reviews
Yes you can. I started a thread with the same question a couple yrs back and Dave was kind enough to chime in and this is what he said...
Originally Posted by TeamPSI View Post
The only difference in the motors is in the shape of the bottom plate. You can run both motors with identical parts and be 100% fine.
The soft parts in the 02-03 are "the same" but different from the 04-05.
02-03's use a single stiff spider, a slightly softer cone, and silicon jacketed leadwires (which ******).
The 04-05 uses a dual soft spider , a stiffer cone, and free floating braided leads.
Refs -
and many more...
The Following User Says Thank You to $LICK CALIFA$ For This Useful Post:
TeamPSI (07-28-2014)
Old 07-28-2014, 04:59 PM
0/11 ssssss586
Thanks man. I actually found a 02-03 motor and I plan on running two 12s for my next build. You only live once..
FS: SS XXX Motor + SS XXX 15" Basket + Recone + More **Pics** zeuslicious Speaker Accessories & Parts 15 03-01-2013 11:10 PM
RE xxx and soundstream xxx ray60218 Craigslist Deals 9 06-06-2012 09:17 PM
Pre pre-ordering (not a typo) pricing for subwoofers. Electrodynamic General Car Audio Discussion & Questions 101 12-07-2010 12:30 AM
SoundStream XXX 15's & 2 XXX-6500D amps AtomicInstalls Wanting to Buy (WTB) 22 10-24-2010 09:57 PM
04/05 XXX motor/ SS XXX basket 1ndatrunk General Car Audio Discussion & Questions 29 10-21-2010 12:27 AM
