custom subwoofer? - Car Audio Classifieds!
Old 03-22-2011, 07:45 PM
0/11 ssssss124
Default custom subwoofer?
i hope im posting this on the right spot but im looking to get a subwoofer built from scratch ive been told by alot of people to check out your stuff can you give me price quotes on here
Old 03-27-2011, 01:26 AM
0/11 ssssss124
If it helps its a re mx basket and motor
Old 03-27-2011, 01:36 AM
0/11 ssssss278
Answer these questions so he will know exactly what you want:
We need to know:
What size does it need to be?
What impedance you will need?
How much power does it need to handle?
The enclosure size or vehicle you'll use it in?
Will you be competing with it? Competitions only?
Any special colors?
Upgrades of any sort? Direct leads, carbon fiber dustcap?
Any budget in mind?
2001 Ford Explorer
Kenwood KDC X794
Front Stage:
CCX65
Rear Stage Kenwood 6x9 4-way
Two Sundown Audio 15 Hybrids
1 Mechman 270 Amp
1/0 Throughout
1 T10001BD (Power Series)
1 Crescendo
1000c4
Music: 146.4
Burp: 146.1 Legal
Old 03-27-2011, 04:24 PM
0/11 ssssss124
It's gotta be a 15 d2 its going to be in a 4. Cube box tuned to 35 Hz for daily use mostly listien to rap songs with heavy bass I'd like it to be able to hold 3k-4k Max Watts I'd like to get the carbon fiber f*** it logo ....the sub I have is in perfect working condition now. The re mx have the Neo magnets would it be possible to get a more heavy duty bigger magnet on there
Old 03-27-2011, 05:15 PM
0/11 ssssss345
Do you want a custom sub from David's PSI line of drivers or do you want your RE sub reconed? I can't tell from your posts. If you want a recone, but want a different motor then it is up to you to find the motor. If this is the case, it would probably be easier to buy a PSI brand sub to fit your needs.
In either case, he will do his best to meet your goals. He's my "custom" sub - Quote on Franken-woofer Assembly - Car Audio Classifieds
Old 03-27-2011, 05:47 PM
0/11 ssssss124
Would it be possible to get quotes on both either just getting my re reconed. Or having it rebuilt ...would having it reconed change the power handling and to have it rebuilt I would need to find a motor correct? And would any motor I find work or is there specific ones
Old 03-27-2011, 06:43 PM
0/11 ssssss345
I'm sure David can supply both quotes.
Reconing can definitely change the power handling depending on the parts chosen.
If you find a different motor to have it rebuilt, then the only original part is the basket.
After looking at the MX line of subs, why do you want to change the motor? Since that sub doesn't use any standard parts, finding a different motor will be difficult if not impossible.
Then why the recone?
If you can find one that fits, you can probably get a bigger magnet but not one more powerful. Neodymium magnets are known for their strength. Just because a magnet is big doesn't mean it is more powerful. You have to look at the material and motor design.
Old 03-27-2011, 06:55 PM
0/11 ssssss345
After doing a little searching, you may be SOL - Probably the last RE MX I ever build.... - Car Audio Classifieds
Old 03-27-2011, 07:46 PM
0/11 ssssss124
I see now pretty much what I was aiming for was to change the re mx to a spl sub but now I think I may just sell it nd start from scratch so now is there a list of parts or would I just find a motor and basket and leave the rest to Dave and also how would I know if the parts fit each other o and by the way that re mx was great
Old 03-27-2011, 07:51 PM
0/11 ssssss124
Or would it be possible to do what you did to the other re mx with the oak
Request for a Custom Subwoofer Erikls9210 (PSI Car Audio) 5 04-22-2010 11:12 AM
Custom subwoofer question DonH (PSI Car Audio) 7 02-20-2010 03:14 PM
[TRADED] 18" RE MT CUSTOM Subwoofer! got160s? 18" Subwoofers 9 01-31-2010 08:49 PM
[SOLD] F/S Custom 3hp Neo TeamPSI Subwoofer thedukey42 12" Subwoofers 9 05-26-2009 09:47 PM
