15" Home Theater sub - Car Audio Classifieds!
Old 04-23-2011, 04:52 PM
0/11 ssssss169
Default 15" Home Theater sub
I have seen you have built a HT sub here and there, I would like to get a quote on the cost of a 15" HT sub, the amp I will be using is a Bash 500(so figure [email protected] ohms).
So basically looking for a low fs 15 that will work well on 500 watts, cosmetics aren't too important as it will be in a downfire ported box.
Old 04-26-2011, 01:27 PM
TeamPSI's Avatar
0/11 sssss4041
How large of a box? Tuning?
Budget?
-David Moore
Old 04-26-2011, 05:09 PM
0/11 ssssss169
Box is about 3.7 cubes after displacement, tuned to 26Hz using Aeroports, but from what I have read HT subs like larger boxes than there Car Audio Counterparts, so if thats the case, I have 2 sheets of MDF in my shed I can use to build a larger box.
I would like to keep the cost around $200 or less, but thats not set in stone.
If a 12" would work better in the box I currently have, then I could go that route as well.
Old 04-26-2011, 07:59 PM
0/11 ssssss345
Hopefully it is near your budget but if David can build you something with similar specs as a Soundsplinter RL-p, then it could be built into an awesome home theater sub.
[ SoundSplinter Subwoofers - RL-p 15" Subwoofer Information ]
As far as tuning goes, I consider 26 too high for a dedicated home theater sub. Also, you will need an amp with a subsonic filter pretty high as well.
For my home theater, I use sealed enclosures and a pro amp (Behringer EP-2500). No subsonic filter (not needed) and a parametric EQ (Behringer Feedback Destroyer) to flatten the in-room response down to 17hz and usable output down to about 14hz.
Old 04-26-2011, 08:06 PM
0/11 ssssss169
I can easily drop the tuning, with the aeroports, any input on box sizes, do they you want a box on the larger side or smaller side etc.....
Old 04-26-2011, 09:51 PM
0/11 ssssss345
Box size really depends on your final goals. There are guys at AVS that put an RL-p in a 12 cubic foot box tuned to 10hz. You could probably go as small as 4 cubic feet if needed.
What about your amp? Make? Model?
Old 04-27-2011, 03:37 PM
TeamPSI's Avatar
0/11 sssss4041
IMO, we don't need to go as large as an RL-P to get the job done here, especially considering the power level, and the enclosure being built around the sub. Our new 2011 Platform 1 motor would work very well for this.
For a 15"... 4ft would do, but you'd be better at 6ft if you have the space to lose. I'll need to know where you want to go on the size before I build the sub though.
I'd tune this sub to 18-20hz if it were mine.
In my HT setup, I use (2) 15's (similar to what we'll make for you) with (4) 18" PR's, 8cuft tuned to 18hz. Just FYI.
-David Moore
Cool little home theater 12"... TeamPSI (Fix My Speaker) 2 04-06-2011 09:52 PM
Using an 18" for home theater. MJ or ILX? SinCron General Car Audio Discussion & Questions 23 02-10-2011 01:04 PM
WTT 10" AQ HDC3 for Home Theater Reciever CaptainzPlanetz Car Audio Trader (WTT) 5 01-31-2011 05:37 PM
wtb home theater sub amp tc3k101 Wanting to Buy (WTB) 10 06-10-2009 01:20 AM
home theater horn korey_hofer General Home Audio/Video 21 06-04-2009 12:46 AM
