Platform 2 12" for SKIZZA - Car Audio Classifieds!
Old 07-11-2011, 11:17 PM
TeamPSI's Avatar
0/11 sssss4041
Default Platform 2 12" for SKIZZA
-David Moore
Old 08-02-2012, 04:48 PM
0/11 sssssss31
After many mods on my car, I'm JUST getting around to installing these and have two questions:
  1. My initial build specs were for subs that could handle 1000W and work optimally in 0.65 cu. ft. ,Lft- 0.71 cu. ft. airspace. Now it appears my new enclosures will be closer to .5cu-.6cu airspace. Will this cause a problem, or will I be ok with slightly less airspace?
  2. What is the excursion on these? Need to have grilles put on but want to be sure I have enough room.
Old 08-02-2012, 09:39 PM
0/11 sssssss31
Also, can you send me a full spec sheet for my build? Since I'm having new enclosures built, might as well build them to spec
Old 08-03-2012, 10:59 AM
0/11 ssssss345
1. Your Qtc and Fs will be a little higher. But you can add about 1/2 pound of fiberfill (use half of a 20 oz bag from Wal-Mart) and that will counteract the 10% smaller enclosure.
2. This is a complete guess on my part but based on the picture of the coil you are using. It looks similar to the one that PSI used on a sub of mine. I asked and he said it was about 22mm. You are going to need a bar grill system. If you are going with a waffle grill then you need some pretty big stand-offs to move it away from the driver.
David only pulls T/S parameters when you pay for them. He has to break in the driver for a few hours and then go through a detailed process to pull them. If you need them now, you need to find someone with a Woofer Tester from Parts Express.
Old 08-03-2012, 12:39 PM
0/11 sssssss31
Cool, thanks for your help Robert
Old 08-07-2012, 11:50 AM
TeamPSI's Avatar
0/11 sssss4041
YGPM SKizza
-David Moore
Monster Platform 3 12"! TeamPSI (PSI Car Audio) 7 07-12-2011 10:21 PM
12" Platform 2 for Ryan J. TeamPSI (PSI Car Audio) 0 07-11-2011 11:17 PM
Another Platform 3 18"!! TeamPSI (PSI Car Audio) 0 07-11-2011 11:00 PM
Platform 1 15" for Phil P TeamPSI (PSI Car Audio) 6 04-15-2010 12:52 AM
Platform 1 12" for Orangelss TeamPSI (PSI Car Audio) 30 04-14-2010 03:57 PM
