Home theater build - 15" Platform 1 - Car Audio Classifieds!
Old 08-22-2011, 05:20 PM
TeamPSI's Avatar
0/11 sssss4041
Default Home theater build - 15" Platform 1
Customer needed a SVC 4 ohm setup, with a long set of leads.
This was built for 1000w rms, sealed.
-David Moore
Old 08-22-2011, 09:03 PM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Approximately what would this cost without the direct leads and CF dustcap?
Old 08-22-2011, 09:11 PM
TeamPSI's Avatar
0/11 sssss4041
$210
-David Moore
Old 08-24-2011, 04:20 PM
Brand New Members
0/11 ssssssss3
Looks exactly the same I ordered!... Is this mine?! :P Btw; I picked up today at post office and build quality is top notch!.. Driver feels heavy; around 30 pounds and looks awesome; better than in pics!.... I just need to know the polarity!. I can assume the blue is the positive; but I need to confirm with PSI!....
QTS/QES parameters are very high. Qts- 0.94, Qes - 1.07. I'm going to use it for a sealed enclosure for my Home Theater. The reason why qts/qes are too high is because I added another spider layer. Usually is one layer; this has two-layers. What I did not know is that layers affects qts. I would prefer a lower qts/qes; around 0.5-0.6. I prefer a tight and punchy bass than boomy bass. So; not sure what qts/qes parameters needs to be for a tight/punchy bass. Another question is polarity: which one is the positive; the blue or black cable?
Old 08-24-2011, 04:38 PM
TeamPSI's Avatar
0/11 sssss4041
Yep, thats yours!
Blue is +
Quit worrying about the numbers man... I assure you that you couldnt tell me in a blind test the difference in sound from a 0.5 Qts versus a 0.8 Qts in the same box.
It will be in the .7's after it's fully broken in.
-David Moore
The Following User Says Thank You to TeamPSI For This Useful Post:
javygonx (08-24-2011)
Old 08-24-2011, 04:47 PM
Brand New Members
0/11 ssssssss3
I'll appreciate your answers. Thanks again!... Should I use "threaded inserts or t-nuts"? If so, then which size is recommended?
Old 08-24-2011, 05:21 PM
TeamPSI's Avatar
0/11 sssss4041
I would use drywall screws myself.
-David Moore
Old 08-24-2011, 05:34 PM
0/11 sssss1286
for 200 bucks that is pretty sick
Old 08-24-2011, 05:44 PM
Brand New Members
0/11 ssssssss3
What is the Vas Value on this custom driver?
15" Home Theater sub CaptainzPlanetz (PSI Car Audio) 6 04-27-2011 03:37 PM
Cool little home theater 12"... TeamPSI (Fix My Speaker) 2 04-06-2011 09:52 PM
Using an 18" for home theater. MJ or ILX? SinCron General Car Audio Discussion & Questions 23 02-10-2011 01:04 PM
Old TC Sounds home theater build article. BlackWaterOp General Car Audio Discussion & Questions 4 05-10-2010 02:06 AM
Home theater build bumpin buick Off Topic Chat 1 12-20-2008 03:19 AM
