Bad recone by psi! - Car Audio Classifieds!
Old 09-15-2011, 06:09 PM
Jokerr's Avatar
0/11 sssss2279
Feedback Score: 33 reviews
Default Bad recone by psi!
Images showing the different heights on each side of the former, there is NO WAY the surround is going to get to the correct location on the basket. I am pushing it as far as it goes in the pic
The cone is not in the correct location on the former. I need a recone that fits!
I buy blown amps,
Old 09-15-2011, 06:11 PM
0/11 sssss4519
Ok, why jump to a thread instead of sending a PM first?
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 09-15-2011, 06:13 PM
tacomaguy1's Avatar
0/11 sssss4401
1. email him
2. send recone back
3. receive new recone
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-15-2011, 06:15 PM
Jokerr's Avatar
0/11 sssss2279
I have been conversing through pm with him
I buy blown amps,
Old 09-15-2011, 06:16 PM
Jokerr's Avatar
0/11 sssss2279
Originally Posted by tacomaguy1 View Post
1. email him
2. send recone back
If only it was that easy
I buy blown amps,
Old 09-15-2011, 06:30 PM
0/11 ssss31247
I believe you need a different recone.. set for your dimensions.
Calling the dude out might not be your most beneficial decision but.. it's a decision.
What specs did you provide them with?
What are the specs of the recone you received?
You know the height of the former does not dictate the height from coil to the surround.. or the height from surround to spider... right?
{because different coil assemblies can have different heights of formers (top o' winding to top O' former)}
Good luck with your efforts.
Old 09-15-2011, 06:36 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
are the spiders sitting flush? or is it just the surround in that one area?
SHABAM
Old 09-15-2011, 06:43 PM
0/11 ssss31247
it appears to touch on the left side and be up on the right.
could be just the spider not being perfectly flat.
Old 09-15-2011, 06:44 PM
Jokerr's Avatar
0/11 sssss2279
Yes the spiders are sitting down flush
I buy blown amps,
Old 09-15-2011, 06:47 PM
DonH's Avatar
0/11 sssss6645
if the spiders are flush and one section of the surround is lifting and the other is sitting down then its not even an issue. surround can get a little deformed out of place when being shipped if layed on the side etc. happens a decent amount of times... lay the bead on the spiders, leave the bead off of the surround. let the spiders cure a wee bit then lay the bead for the surround and clamp dat bish. even if the surround is lop-sided now it wont be in due time.
SHABAM
Bad Recone bigdhenderson General Car Audio Discussion & Questions 54 08-05-2011 07:10 PM
PSI AQ HDC318 HD Recone D1 Bsktbll895 Speaker Accessories & Parts 15 12-27-2010 03:34 PM
Re HC with psi drop in recone sqoverspl (Fix My Speaker) 1 09-21-2010 03:26 PM
Thanks PSI for such a speedy recone. paaco1981 (PSI Car Audio) 15 09-13-2010 04:16 PM
recone subbie mr. psi upzaw2000 (Fix My Speaker) 8 08-18-2009 12:07 PM
