Car Audio Classifieds
Go Back   Car Audio Classifieds > Car Audio Help & Discussion > Car Audio Product Reviews
Car Audio Product Reviews Post detailed reviews of products you have personally used.
Need a sub repaired or reconed, click this link for your best solution!
Thread Tools Display Modes
Old 12-31-2009, 10:08 PM
BigC-Expo's Avatar
BigC-Expo BigC-Expo is offline
White fish to purple lamp
0/11 sssss4544
Default Real world AP3000D Clamped Tests
So tonight we took a few hours and sdelthon and myself did some testing on one of my Audiopipe AP3000Ds, I havent clamped one of these for some time now, and wanted to do a nice lil test and result page about them!!
Car used sdelthons 94 T-Bird
Deck used Sony CDX-GT63UIW 2volt preouts
Stock ALT
1 run of 1/0 Audiopipe power
2 Treo SSX100Bs and a Treo SSX75B
1 Ap3000D
2 Treo SSPs 10s dual 2s reading slightly different, final ohm load before rise coming out at 3ohms
Ohm Load calculated after imp rise
So after 2 hrs of play time and a weak charging system the amp is still very strong, and if we could hold in that 14volt range at 2-2.5ohms we will be able to get all of 3kw+ like rated then some, so for $299shipped with warranty these are the best amps on the market for the money, and ill be running 4 of them!!!
Audiopipe AP3000s Amp gain lil below half
Test#1
Resting voltage-12.50volts
Voltage drop-11.6volts
Power-2014.32
Ohm load-3.77
Amps Voltage-87.2
Amp Current-23.1
50hz test tone
Deck sublevel at +6 out of 10
Volume 30/50
Test #2
Resting voltage-13.88
Voltage drop-12.5volts
Power-2489
Ohm load-3.6
Amps Voltage-95.0
Amp Current-26.2
50hz test tone
Deck sublevel at 10 out of 10
Volume 30/50
Amp gain lil over 1/2
Test #3
Resting voltage-13.83
Voltage drop-12.5
Power-2675.34
Ohm load-3.7ohm
Amps Voltage-100.2
Amp Current-26.7
50hz test tone
Volume 30/50
Final test with video
Resting voltage-13.66
Voltage drop-12.4
Power-2525.95
Ohm load-4.208
Amps Voltage-103.1
Amp Current-24.5
50hz test tone
Volume 35/50
TEAM GORILLA
TEAM GHOST MOB
1998 Expedition Eddie Bauer
~up coming build~
2 21" Crescendo Audio Monsters
2 Crescendo Audio 5kws
4 C&D Tech 75ah rear
MM 270 alt
Walled behind the 2nd row seat tuned to 30hz
**THE NUKE**
Straight Murder to your ears!!
Forum Jump
SounDigital cars at World Finals - WORLD CHAMPIONS!!! muriloalvares (SD) 10 11-22-2009 10:14 PM
SounDigital cars at World Finals - WORLD CHAMPIONS!!! muriloalvares Competition Corner 10 10-17-2009 10:31 AM
Saz3500d tests please!!! BigC-Expo (SA) 15 10-03-2009 06:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Car Audio Classifieds © copyright 2008 All Rights Reserved.
Created, managed and owned by Patrick D Simmons
Content published on Car Audio Classifieds requires permission for reprint.
