What I Learned My First Time Doing Fiberglass A Quick Tutorial - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Enclosures, Fabrication & Sound Deadening > Sound Deadening & Fabrication
Sound Deadening & Fabrication Any questions or discussions about fiberglassing go in here. Questions and discussions about sound deadening also go here.
Old 06-09-2017, 06:43 PM
nkrell11's Avatar
1/11 sssss1385
Default What I Learned My First Time Doing Fiberglass A Quick Tutorial
Alright so I've never wrote a tutorial or anything like this before so please bear with me. I'm not a pro by any means this was my first time ever doing anything like this I just wanted to share what I had learned. This post may be a little long winded I apologize in advance. I watched some youtube videos before attempting this but most of them weren't very helpful in my opinion. This is the best one that I watched gave some useful tips especially for mixing resin. There's a 50 minute video but ain't nobody got time for that.
https://www.youtube.com/watch?v=ZMJ0YZmc1Bc
I'll start out with a list of supplies that I used not all are mandatory but they are all certainly helpful. I used bondo fiberglass resin and fiberglass mat just because I wanted something small to get my feet wet. If you plan to go large scale I would suggest US composites (I ordered through them to get the stuff for when I do my doors).
-Fiberglass Resin
-Fiberglass Mat (Seems like 1.5oz mat is popular)
-Ponte Fabric
-Body Filler (I used Rage Gold but I know there are other options)
-2 Inch Chip Paint Brushes
-Disposable 9 oz Dixie Paper Cups
-Stir Sticks
-Disposable Gloves
-Router or a Jigsaw would do
-Dremel definitely not necessary but really helpful
-Sand Paper I used 120,220 and 320 grit
-Dowel
-Hot Glue
-Stapler & Staples
-Spray Adhesive
-Wood
-Whatever you want to cover them with
Alright so first step was making my rings to mount the tweets in, I used a plunge router and a small Jasper jig but you could get by with a jigsaw or a hole saw if you didn't happen to have a router.
Afterwards it was time to mount the rings to the pillars. I understand that most people use hot glue and dowel to mount them. I just used a couple small wood blocks and a couple wood screws. Make sure you have enough clearance on the back side of the rings to clear your tweeters.
Next it's time to wrap your work piece in fabric, I used ponte which you can find at the fabric store it's nice and stretch which helps in avoiding wrinkles. Some people use fleece but it takes a lot of resin and doesn't really add strength so it's not your best choice. I used a combination of staples, spray adhesive and hot glue to attach the fabric. I'll have a note about the spray adhesive later though.
Alright next step is application of your resin. I believe each ounce of resin requires 10 drops of hardener. I mixed small batches to avoid waste and not having to worry about working super fast. Ok here's what I didn't know DO NOT APPLY RESIN TO SPRAY ADHESIVE IT CAUSES IT TO DISBOND!!!! You can see where I had to put staples in the top because I did not know this, I also applied it to the back and it cause things to disbond but I got lucky and didn't have any long term problems. Let resin cure according to manufacture specs.
Next step apply fiberglass mat. I tore mine into pieces as I didn't have scissors on hand. I painted down a little resin first then set the mat on and then applied resin over top. Try and avoid any air bubbles you can see them underneath usually, they cause weak spots in your project. Afterwards let cure don't worry you can always add more later where you need it. In this picture I had already sanded down some high spots etc.
Alright after you get all your mat on and your project feels solid it's time for body filler. Tips for this in my experience are don't lay it on to thick you can always add more but its a pain to sand off too much. Don't apply filler if you don't have time to sand it gets harder the longer you wait. After it dries up sand it down you kind of just have to go by feel. Sadly I don't have any pictures of this step but you'll know when you have it right I guess.
Lastly prime and paint or wrap your project. I used duplicolor spray on bedliner. It worked great and was just what I wanted as I didn't want a smooth finish. Here's my finished product. I hope this tutorial has helped anyone that reads it in some way. The biggest key is patience you can't get in a hurry when doing this stuff it will lead to mistakes that are hard to go back and fix.
Under Partial Reconstruction
Build Log:
Old 06-09-2017, 08:00 PM
1/11 ssssss218
They turned out great! And for a first try, (probably really taking your time) even better!
Pioneer 80PRS,2 sets of Pioneer TS-110 tweeters, Fountek FR89EX 3" midrange, Silver Flute 6.5s, 3HP, 4HP, Zv4s and other stuff.....
Old 06-10-2017, 11:58 AM
1/11 sssss2031
Beautiful job. Looks really good.
Old 06-11-2017, 09:05 AM
nkrell11's Avatar
1/11 sssss1385
Thanks guys, I just plugged away at them after work until I finished them. I'll probably post more tips and stuff when I do my doors and beauty panels.
Build Log:
Old 06-22-2017, 06:28 PM
nkrell11's Avatar
1/11 sssss1385
Alright I got a little more experience with some fiberglass work, these didn't come out perfect but I'll try and highlight why in this portion of the tutorial. I'm still satisfied with the outcome (probably because they're in the very back where I won't have to see them all the time).
Anyhow first step was constructing my frames, I had to tilt the circles for the fans to get enough clearance:
After wrapping the frames in fabric it's time for some resin. You can use the factory gasket to hold your fabric in place and get it stretched how you want it. I would suggest adding some layers of painters tape to whatever you don't want resin on. I used the US composites resin I bought on these and you can definitely tell the difference it seems to go farther and it doesn't have such a gooey consistency.
Ok after your resin cures it's time for the fiberglass mat. Here's where I messed up I didn't put enough resin on to harden my edges enough so when I applied my mat the edges of my passenger side panel kind of warped or sagged. So make sure your edges are thoroughly hardened. Also I did my mat on the back of the panels if you can do this it will save you a large amount of sanding/filler work in the future.
Ok once your glass is nice and cured it's time for some filler. Can't really describe exactly how best to do it I just go by feel. Another tip is that if you lay your filler out thin on whatever you mix it on it hardens more slowly than if you just leave it in a big glob. To be honest I probably could have done some more sanding on these but I was pretty sick of it to be honest.
Lastly coat it however you want, for me it's more spray on bedliner but to each their own.
Build Log:
nkrell11's Avatar
1/11 sssss1385
Build Log:
Old 06-22-2017, 07:32 PM
1/11 sssss2031
Keep at it soldier. Looking good
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Quick time lapse of building Skip01 single 8 box dcarcstms Car Audio Videos 21 07-28-2012 09:13 AM
Lesson Learned... nicholask1993 General Automotive Chat 2 09-11-2011 06:48 PM
fiberglass resin on box quick question mrfantastic911 General Car Audio Discussion & Questions 19 11-20-2010 08:29 PM
Well....i learned something today upzaudio General Car Audio Discussion & Questions 11 10-22-2010 08:33 AM
car audio forum, moble audio, car stereo, wholesale car audio, 12 volt, with, amplifier, amp, subwoofer, sound quality, buy car audio, and sell automotive stereo systems for cars Plum is my hero!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
