Originally Posted by DonH
if you are running active off your 9886, simply set the crossover section on your amplifier to full or through or off w/e it may have for only the tweeter channels, next set your desired frequency cutoff and slope on the 9887... that simple. do all of your filtering from your headunit, and none from your amp.
The crossovers selections on my 9887 are
60hz/80hz/100hz @ 0/6/12/18/24 db slope
That doesn't really help me. I have my mids on full pass at the amp and tweeters on highpass (400hz)
In my EQ setting I can set 2.5/3/4/5khz @ Q of 1/1.5/3
