Need Advice on Components - Car Audio Classifieds!
Old 07-13-2012, 02:02 PM
dowork's Avatar
0/11 sssssss93
Default Need Advice on Components
Now that I've successfully built a serious daily ground-pounder, I want to improve my front stage. By improve I mean in SQ as well as more output.
I'm currently running these Pioneer components on this Alpine 4 channel.
They sound decent to me (on rap hip hop), but the tweater is REALLY bright, the vocals sound "like tin" to me and the midbass is almost non-existent.
My main question is:
Most 4 channel amps are 2ohm stable but most components are only rated around 80 RMS, even the higher end Hertz and Focal's.
What are people running for high end components that have good SQ and get loud - and are they running 2 or 4 ohm?
Hummer H2 ** 6 SA 12's ** 2 SAZ 2500's ** DC 300a Alt ** 2 D3100's ** 200 sq ft DeathMat
Old 07-13-2012, 02:13 PM
Matt3824's Avatar
0/11 sssss3754
Budget?
Old 07-13-2012, 02:18 PM
dowork's Avatar
0/11 sssssss93
I'm rich beotch. Just kidding.
If my amp is good enough then I'm OK dropping 5-600 or so on comps.
Old 07-13-2012, 02:31 PM
Matt3824's Avatar
0/11 sssss3754
Is that for 2 sets?
Old 07-13-2012, 02:34 PM
dowork's Avatar
0/11 sssssss93
I've got a set of Hertz coax in the rear that I'm OK with, so only looking to upgrade 1 set of components in the front right now.
Old 07-14-2012, 12:37 AM
0/11 ssssssss9
my hertz hsk 165s are rated 125rms per side and that's what i am running to them at 4ohm
Old 07-14-2012, 12:40 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
just go with the focal utopia
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 07-14-2012, 12:43 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
you want good sq but still loud I would buy selenium mids and some dayton tweeters and run em active.
Current Build:
#60sHereIcome
Old 07-14-2012, 12:20 PM
kreapin's Avatar
threw the hood
0/11 ssssss894
Look into CDT, they have a few sets that run 2ohm and hold pretty good power.
Old 07-19-2012, 06:41 PM
Brand New Members
0/11 ssssssss4
I have a set of Hertz 3 way components (the HSK163's) that I ran with about 200 watts per side. They did really well and got plenty loud. Honestly something with a softer dome on the tweeter will sound good and help with the brightness that you had in the old sets.
Need Advice on components stylez12321 General Car Audio Discussion & Questions 5 01-30-2012 06:00 PM
need advice optical General Car Audio Discussion & Questions 27 09-02-2010 02:32 AM
Advice on my next sub lslugz (PSI Car Audio) 6 05-11-2010 09:02 PM
need advice Kyle K Off Topic Chat 10 03-10-2010 09:39 AM
little advice? Snwbrdr1 General Car Audio Discussion & Questions 12 03-23-2009 08:56 AM
