Another SQ noob needing help - Car Audio Classifieds!
Old 09-18-2012, 02:00 AM
maverickdog8's Avatar
0/11 sssss2979
Default Another SQ noob needing help
I am needing to upgrade my speakers badly as they are currently all stock.
Head unit:
I am going to run a Pioneer PRS80 or a AVH-P6300BT as my head unit to replace my current Clarion VZ401.
Speakers/Tweeters:
Thinking about 2 sets of AQ super tweeters for the pillars(2 in each pillar) and was going to do 2 6.5 pro audio drivers in each door, but am looking for opinions on them.
Amp(s):
I was considering just picking up the Crescendo C1100.4(most likely the older one), but once again. Looking for opinions.
Now the biggest issue is I have no idea about crossovers or processors and what I need for that area.
Any help would be appreciated and I'm not to worried about the budget. It is going to be an over the winter project, but lets keep it halfway cheap and not outrageous(no zed audio or anything that pricey, even tho they are sweet lol).
Old 09-18-2012, 02:07 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
The product I would buy for active processing is a mini dps 2x4
MiniDSP 2x4 RevB | miniDSP
As long as you have a computer you can change the xover settings as you like.
Generally speaking you HPF mids 80 to 100hz and LPF them from 2khz to 4khz depending on the mid. Then the tweets HPF 2khz to 4khz depending on the tweet.
Current Build:
#60sHereIcome
Old 09-18-2012, 02:10 AM
0/11 sssss2979
Is active the way to go?
SINTORMAN's Avatar
0/11 sssss4907
As for tweets and mids as long as you go with something you have seen quite a few guys run before you should be fine. I wouldn't use your first time around to try out a no name brand.
That amp should work fine too.
Current Build:
#60sHereIcome
SINTORMAN's Avatar
0/11 sssss4907
If you have the means (IE money).. then definitely.
Current Build:
#60sHereIcome
Old 09-18-2012, 02:12 AM
0/11 sssss2979
Whats the perks of going active over passive?
Old 09-18-2012, 02:13 AM
0/11 sssss2979
And I have never really seen anyone run pro audio at all or super tweets locally to me so its all new to me.
Old 09-18-2012, 02:14 AM
SINTORMAN's Avatar
0/11 sssss4907
Better SQ by far. More control over the response in your vehicle.
also passive xovers have limited control over adjusting the tweet to mid output ratio. Running active each speaker will have a gain to it.
Current Build:
#60sHereIcome
Old 09-18-2012, 02:16 AM
0/11 sssss2979
So it may be worth the money to go active and just try to find some decent equipment used for a little cheaper.
SINTORMAN's Avatar
0/11 sssss4907
Look on here and youtube for ideas
People love selenium... Twisted seems to love his new cadence.. etc...
Current Build:
#60sHereIcome
needing help alexis8284 Enclosure Discussion & Design Construction Help 0 07-05-2012 10:07 PM
Needing some Opinions stylez12321 General Car Audio Discussion & Questions 4 04-05-2011 05:47 AM
needing help with port..... Team3d Enclosure Discussion & Design Construction Help 5 12-21-2010 08:56 PM
Needing A Motor big_way32 Wanting to Buy (WTB) 23 05-14-2010 09:38 AM
noob question for a not so noob installer. waresgaragestereo General Car Audio Discussion & Questions 5 03-31-2009 10:38 PM
