SQ box - Car Audio Classifieds!
Old 01-01-2013, 10:01 PM
0/11 ssssss459
Default SQ box
I've played around myself with a couple different subs and boxes in my car but I think its time I look into a SQ option, as while I want to have high output it doesn't mean much to me as I am looking for quality output which spans a semi-large frequency range.
I have a XL 15 on a 3.5K currently, but I'm thinking about going something like 2 10's in a 4th order, or maybe a single 12 in something like a T-Line.
My question is this, what are the differences between something like a T-Line and a 4th order. I know where my car peaks (as I know this makes a big difference when tuning something like a 4th order, although I don't know the math behind it).
Is anyone able to enlighten me on the key differences, like output range, etc. Is doing something like a T line not worth it in a trunk car?
Old 01-01-2013, 10:10 PM
thekeeperofspike's Avatar
0/11 ssssss146
where does your car peak and coupe or sedan
Pure Pressure Concepts
Team Sundown
mwspl-2nd place xtreme trunk 2012
mwspl-2nd place basic trunk 2012
mwspl-2nd place xtreme trunk 2013
mwspl-2nd place basic trunk 2013
Old 01-01-2013, 10:11 PM
0/11 ssssss459
sedan, peaks at 42
Old 01-01-2013, 10:13 PM
SUPER FAST SHIPPING
0/11 ssss31247
my suggestion is simple;
[save your sub and box for later in case you want to move back to SPL]
buy a LVL4 D1 and series the coils for 2ohm, then put it in a 2.75cu ft sealed box firing back into your trunk and turn the SSF all the way down.
you will have respectable / plenty loud SQ and it will impress you.
Old 01-01-2013, 10:18 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Your car's resonant frequency and where your current box peaks are two completely different things.
Do you really want SQ? Like... really? Or does your current shit just not sound good enough?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
0/11 ssssss276
You could do what I did with a 4th order. Instead of a larger ported side do the opposite.
Depending on the sub and box design you can get a fairly flat (in my case same curve, within .5db +/-) curve as you see with a sealed enclosure.
It was more of an experiment when I built it but sounds great. I even moved on to a 4th to 6th switchable convert.
Old 01-04-2013, 11:40 PM
0/11 ssssss459
I've hit a point where I have put probably upwards of 10 systems in my car, I want something that sounds better then what I have. While I enjoy having a system that is loud I want something that sounds good with not just bass music with subs that'll blend with everything instead of just sound loud in the ~40hz range. I wanna experiment
I've always faced my subs forward, I like the sound of it when compared to facing backwards, my current plan was to seal off my xl 15 facing forward.
do you know what having a smaller ported side does? I've only heard a single 4th and it had a larger ported side, 3:1 I believe.
Old 01-04-2013, 11:45 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
The closer you get to a 1:1 ratio, the flatter the response gets. But you sacrifice efficiency. People do large ratios for the big gain you get around tuning.
I did a 1:1 ratio 4th for my 12 last week. It sounded amazing, but the ouput was shit. It was perfectly flat from 28hz - 56hz, but a regular ol' ported box was way louder.
If you want to try something different and SQ is a concern, try a quarter wave. Or do a LLT (large low tuned). I don't have the room for one but the feedback on them is amazing. Would be like 4 cubes @ 20hz for a 12. The idea here is that it acts like a sealed box until you get down near tuning where the port takes over and magnifies the output. DO that shit.
4x world champ
- Floyd E. Toole
Old 01-05-2013, 12:18 AM
0/11 ssssss459
I guess in my mind I keep thinking I have more space then I do, I keep thinking I have more depth and I did before adding a third battery. The only way I can go larger really is by building a box that conforms to my trunk opening a little, could probably squeeze a cubic foot or maybe a little more in doing so.
Would building a larger box but not overly large benefit me in any way ? The power handling of the sub drops with a larger box correct ? And what is a good tunning frequency if say I have 4-4.5CU/ft for a 15 and port area per foot ?
Old 01-05-2013, 10:08 AM
0/11 ssssss276
Do you know what having a smaller ported side does? I've only heard a single 4th and it had a larger ported side, 3:1 I believe.[/QUOTE]
In my application the box is specifically designed around the sub. Specifically made to not sound like a one note wonder as some ported boxes, 4th's. Specifically made to resemble a similar curve as a sealed enclosure. But the gain benefit of a ported enclosure. (3-4 db) I'm no expert as this was a design I had someone else do up for me.
From my understanding the more you increase the ported side past the 1:1 ratio the more peak output you get.
This idea is for those who like the sound of the sealed setup but isn't afraid to give up slightly more space in the trunk in order to get slightly louder.
I also went with a 6th interchangeable conversion as well. Mainly because I'm what you call a hybrid as I enjoy SQ but also like SPL. This gives me that. Granted the 6th isn't as loud as it would be if it were designed for a 6th but with my particular setup I gained another 2.5-3.5 db over the 4th order around tuning.
Good, 3+ cf ported box for a 12 inch sub or a box builder (central WI) Wingman0121 Wanting to Buy (WTB) 0 06-16-2012 08:58 PM
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 02:43 AM
Box design request for da box king ( 2-12" R's) da box king Box Requests 3 08-16-2010 04:23 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
