3way active front stage + sub problem - Car Audio Classifieds!
Old 02-20-2013, 12:03 AM
0/11 ssssss229
Default 3way active front stage + sub problem
how can the headunit (9887/80prs) run a 3way active front stage and sub output with only 3 sets of outputs and maintain full active capabilities/time alignment?
Old 02-20-2013, 07:55 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
They can't.
That gets confused a lot. Those decks are technically "3 way active." But in more specific terms they're 2-way + sub.
To confuse things further, when someone mentions running 3-way active, they're almost always talking about a 3-way FRONT. Or technically 4-way active or 3-way plus sub.
There are very few decks that are 4-way active. My Pioneer p99rs being one of them. Or the Clarion drz9255 I used to have. Most 4 ways are accomplished with an 8 channel processor.
Clear as mud? Lol.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 02-20-2013, 09:00 AM
hotzie's Avatar
changin the game up
0/11 ssssss793
hey on the 80 when you set it up to run active , 2 way and sub in my case will it lose the ability to run the internal amp. Will i lose the ability to run my rear speakers off hu power i know there is a couple settings on the processor for std and ntw and something else , i thought one was kinda a mix.
Old 02-20-2013, 09:45 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
There's a standard and a network mode. There's also a high level and low level output switch. I'm not sure if the high or low level switches disable the speaker level outs or if it just diverts some of the power or what. You'll have to check the manual if you can decipher it.
4x world champ
- Floyd E. Toole
Old 02-20-2013, 09:50 AM
0/11 sssssss13
Running 4-way with those units is possible and still utilize t/a functions. The sacrifice is driver location. Of course you will have to split one of the outputs (mid or high) with a separate xover, but the midrange will have to be I'm close proximity to either the midbass or midrange. IE whichever one is sharing the headunit's output.
Also, I would opt for a xover that has phase shifting capabilities so you can better align the midrange to the midbass if using that configuration and the mid is a little bit of distance away from the midbass than what's optimum. Something similar to one of the Lanzar Opti-X is ideal. Once you align each midrange to it's relative midbass, then you can time align that side to the rest of the system.
Old 02-20-2013, 09:54 AM
0/11 sssssss13
Sorry about the grammatical errors. Mobile won't let me edit.
Old 02-20-2013, 11:21 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
That isn't exactly 4 way active though, is it?
I ran a 3-way front with my 80. Woofers fully active, mids and tweets on the passives. I could still time align the mids but the tweeters got the same delay. And they weren't in close proximity. But I had attenuation on my passive crosses so I used that for intensity differences between the tweeters.
It can work if you put in the time, but I gave up on it when I just disconnected the mid, went active with the tweet and it sounded better.
4x world champ
- Floyd E. Toole
Old 02-20-2013, 11:43 AM
0/11 sssssss13
Ideally, you would want to leave the tweets on their own channel coming from the HU rca.
An outboard xover (amp or whatever) can be used to split the P80's bandpass rca between mid & midbass. Not too bad as long as you are using door midbass & kicks midrange, or something similar with distance between the two not too far off. With the Lanzar's phase shift you can get the mids to mate up with the midbass although it will have to be done by ear. Once set, time align the summed midbass/midrange set (per side).
Still active as you will be able to control xover points separately for tweets, and the outer limits for the bandpassed pair from the HU. The split between the midbass/midrange will be set it & forget it while driving. Not a bad trade-off considering cost of something comparatively capable.
Old 02-20-2013, 12:27 PM
0/11 ssssss627
The critical part here is driver placement. Secondary but equally important is having level adjustability on each driver. When you get the levels matched from the beginning everything else falls into place much more easily. Right now it's considered the "right" way to put a mid and tweeter together on axis on the A-pillars and fit the midbass drivers where it's convenient, but things really come together when you put the midbass, midrange, and tweeter all close together on the door. You still have to get the tuning right, but you will probably find that time alignment done manually is a lot easier with that type of driver placement. It also gets rid of reflections off the near door glass, which tightens up the imaging.
Old 02-20-2013, 12:34 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Respectfully disagree.
Even with woofers in door and mids in kicks, that's still further than quarter wave away from one another at a good crossover point. And since midrange is still affected by ITD, I'd much rather have control of them separately. Tweeters are easily aligned by attenuation. They also don't need a band pass. And phase is no sweat.
It would also be waaaay easier to get a tweeter in close proximity to a mid than it would be to get the woofer and mid together. Close enough that they'd essentially be a point source. The only sacrifice (maybe) is stage height. And that's debatable.
While I'm sure you're method could work, and maybe its working for you now, I wouldn't consider it ideal.
4x world champ
- Floyd E. Toole
Active loud front stage package jdmferio13 Car Audio Packages 2 02-07-2013 09:59 AM
another active front stage question thegr8cody General Car Audio Discussion & Questions 1 10-16-2012 11:47 PM
Front stage problem.Need help. sherrod833 General Car Audio Discussion & Questions 3 08-04-2012 07:14 AM
Question about running 3way active... audioarsonal Sound Quality Area 6 06-06-2011 02:47 PM
coustic 3way active xover snoopysnooper Head Units, Processors & EQs 12 09-08-2010 08:12 PM
