Can increasing the gauge of speaker wires change clarity and power ? - Car Audio Classifieds!
Old 02-21-2013, 02:56 PM
0/11 ssssss260
Default Can increasing the gauge of speaker wires change clarity and power ?
Have my mids in the doors playing lower than the mids in the middle console ran fresh wire to the ones in the middle console. Will larger wire to doors help?
Old 02-21-2013, 03:08 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Have you tried swapping the hookups on the amp to see if it's the amp that is giving the console drivers more power?
Are you using one amp for all 4?
How much power are you pushing to all speakers, and how much power do the amp or amps put out?
team graham
Old 02-21-2013, 03:10 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
i did a test spl wise and gained 0.0db from swapping from 14 gauge to 8 gauge on my subwoofers. I doubt making the wire bigger will make any difference.
Old 02-21-2013, 03:11 PM
tacomaguy1's Avatar
0/11 sssss4401
if it's already sufficent, then going to even bigger would do nothing
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 02-21-2013, 04:52 PM
0/11 ssssss260
Switched wires same thing it's a Mmats 4160 4 Mmats 8's 4 selenium horns andmmats tweeters. 175 @ 2 ohms 4 channels all 8 ohm speakers
Old 02-21-2013, 04:54 PM
0/11 ssssss260
RCA were all the same result and different amps also same. ..... Better off running fresh wires for everything .....?
Old 02-25-2013, 02:05 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
If you are using stock wiring to the doors, that might be the problem. Stock speakers are rated at?? Head units put out 20w rms or so IIRC. They weren't thinking "let's put in speaker wire that will handle 10 times what the stock head unit puts out, in case someone puts in some high power speakers" when they designed the car
It sounds like that is your problem. You can even try one channel on one door and one channel on one speaker wired directly to the door (same distance) with bigger wire. Should tell you if it's the wire size or not.
team graham
Best way 2 make speaker/power wires look GOOD at the amp inputs?(spade/ring terminals graham General Car Audio Discussion & Questions 14 12-17-2012 07:11 PM
FS: 16 gauge speaker wire, speaker terminals, MDF speaker rings YouSirName Wiring, Electrical & Other Installation Equipment 13 02-12-2012 05:04 PM
[SOLD] Random wires(4 gauge, 8 gauge, 12 gauge) Pieper Wiring, Electrical & Other Installation Equipment 4 03-06-2011 01:10 PM
money efficent way of increasing power? murderedtahoe General Car Audio Discussion & Questions 7 01-06-2011 08:25 AM
[SOLD] Stinger HPM 4 power/12 gauge Speaker Wire Pieper Wiring, Electrical & Other Installation Equipment 3 10-11-2010 08:51 PM
