What are the best RCA Cables to use for SQ - Car Audio Classifieds!
Old 02-26-2013, 11:19 AM
Brand New Members
0/11 ssssssss1
Default What are the best RCA Cables to use for SQ
I was wondering what cables are some of you are running. I'm working on my set up for my Jeep Wrangler trying to start wiring it up want to get the best wire for my set up
Old 02-26-2013, 12:46 PM
0/11 sssss1181
I've personally used these with success:
http://www.darvex.com/store/pc/4000-Series-c121.htm Ballin on a Budget
I have used these as well and are a lil nicer connections and lil more noise free
http://www.darvex.com/store/pc/6000-Series-c115.htm lil more money but worth it
If I could do it over I would buy these because everything Coleman makes is the [email protected]
http://www.ebay.com/itm/Audio-Techni...item19d81cc2c6
Old 02-26-2013, 05:54 PM
0/11 ssssss627
As long as you buy RCAs from a reputable company they should be fine. You want to run them away from your power cable and away from sources of power within the vehicle, such as the blower motor, fuel pump, etc. Even then you can sometimes get away with not taking those precautions if your amplifiers have noise rejection for the inputs. Don't spend big bucks on RCAs.
Old 02-26-2013, 06:03 PM
0/11 sssss1181
Not saying you need the best of the best but even great companies like Stinger, Knuconceptz, Streetwires, Scosche all make some junk cables. I feel I should elaborate if you go with a big name company just don't buy the cheapest series any of them make
Old 02-26-2013, 06:12 PM
SUPER FAST SHIPPING
0/11 ssss31247
I have Stinger Hyper series in my truck and they've served me for the last few years without issue.
They are like $20 for the 17ft 4 channel and $12 for the 17ft 2 channel.
I've used lots of Monster 301 rcas, and Stinger Zn3 rcas.
The key to the stinger hyper series is the fact they are small so they are easy to install...
and right now, vertex has Hyper and a few other series on sale.
B-Stock, Demo & Used Items - Vertex Audio
Old 02-26-2013, 06:13 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
ran fosgate twisted pair in all my cars never had a problem with them...i would run them forever. bought off ebay in bulk think my 17 footers were 15 bucks my six footers were 7 bucks.....but i hunt for deals..
Old 02-26-2013, 06:18 PM
richdog102's Avatar
0/11 ssssss925
i ran the hyper series 4 channel and i think they are made kinda cheap....thin shielding. and on 2 separate pairs the pin jacks broke in the casing....but that was just my experience.
Old 02-26-2013, 06:21 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
well do you need differential input or single ended input. or whatever they are called.
Old 02-26-2013, 06:27 PM
SUPER FAST SHIPPING
0/11 ssss31247
If mine did that, I'd be mad.
maybe there's a difference in our installs/drivinghabbits/method of removing connected rcas
my only complaint is those o-rings that mark which channel is which.. they don't stay put.
Old 02-26-2013, 06:32 PM
richdog102's Avatar
0/11 ssssss925
yeah my rings fell off too..and i did not mean the pins broke off in the amp i meant the rubberized end that holds the pin broke so the rca ends would wobble inside the case were the wires would connect to the pin jack...you could slide the pin in and out of the case...they still worked just real cheezy...and they were never directly put into the amps i ran spliters to them and tapped them up they were tucked away nicely so i have no clue how they broke...
Best RCA cables? Wingman0121 General Car Audio Discussion & Questions 35 01-15-2014 03:07 PM
Alpine INAw900BT w/ALPSIR/RCA/Ainet cables all in box w/all cables weehooyou Head Units, Processors & EQs 6 02-09-2012 12:07 PM
RCA Cables SKDooley General Car Audio Discussion & Questions 19 02-12-2011 08:05 PM
rca cables pokerchip11 Wanting to Buy (WTB) 2 02-08-2011 05:15 AM
fs - RCA Cables BeAlLsTaR13 Wiring, Electrical & Other Installation Equipment 8 01-06-2011 09:47 AM
