Need help chosing active 3way front stage sq - Car Audio Classifieds!
Old 03-22-2013, 07:31 PM
0/11 ssssss261
Default Need help chosing active 3way front stage sq
Just as title says im looking for opionion on what to run for active 3way front stage I dont have a budget but would like to keep reasonable on cost..... let me know your thoughts thanks.....
Old 03-22-2013, 07:57 PM
Matt3824's Avatar
0/11 sssss3754
Well whats the most you'd want to spend?
What vehicle?
What substage?
With the info provided I'd say a Vifa 1" soft dome, 4" Dayton midrange, and 8" Dayton midbass per side.
Parts-express.com is a good place to look at raw drivers.
You either need an active deck like the Pioneer 80prs or you need active amps, like the PPI P900.4, in which case you need 2. You could also use a nice 6 channel.
If you provide more info, more people can help.
Old 03-22-2013, 08:35 PM
0/11 ssssss261
2006 chevy equinox
Sub stage undecided
Rockford fosgate 3sixty.3
3way active front stage + sub problem JsUltimateSounds Sound Quality Area 17 02-21-2013 04:49 PM
Active loud front stage package jdmferio13 Car Audio Packages 2 02-07-2013 09:59 AM
another active front stage question thegr8cody General Car Audio Discussion & Questions 1 10-16-2012 11:47 PM
memphis 3way active crossover Mat J Head Units, Processors & EQs 6 03-15-2011 07:54 PM
coustic 3way active xover snoopysnooper Head Units, Processors & EQs 12 09-08-2010 08:12 PM
