Help with front stage - Car Audio Classifieds!
Old 04-11-2013, 12:22 AM
0/11 sssssss11
Default Help with front stage
Thanks in advance. I have a set of Id ctx 65cs that I installed in the front doors of my 2012 f150 supercrew. The sound okay but seem to be lacking a lot of mid bass and the tweeters can get pretty harse and cause some listen fatigue. I am running them off a cadence zrs c9 and I am crossing them over on my headunit @120hz. What can I do to change this up, the speakers while bright ont seem to have much depth sound wise, is this an amp or speaker issue. Kinda getting frustrated with this any help on upgrades or fixes would be greatly appreciated.
Old 04-12-2013, 03:55 AM
How are the speakers fitted into the doors? Are there any gaps around the seal where they are mounted?
You need to work on getting the door sealed off so you don't get rear-wave cancellation, which is the fastest way to kill your lower midrange/midbass. Search for "door treatment" to find more information.
Old 04-12-2013, 08:13 AM
0/11 sssssss11
I have the speakers mounted to some mdf spacers but I pit duct seal between the door and mdf spacer and duct seal between the speaker and mdf spacer. No deadening yet but will just deadening work or do I have to seal it too?
Old 04-12-2013, 12:27 PM
Not a lot of people know about using the duct seal..that's some good stuff.
Deadening won't necessarily help the midbass, but it's usually used in conjunction with sealing because as the inside of the door acts more like an enclosed space it will have a tendency to rattle or resonate. But...because it sounds like you mounted the speaker well I'm wondering if it's another issue. Does it sound better if you adjust the balance all the way left or right so only one speaker is playing? Do you have any other crossovers besides the one on the headunit turned on? any EQ settings that may have the bass turned down?
Old 04-12-2013, 12:32 PM
0/11 sssss8594
Feedback Score: 55 reviews
i loved my 2 sets of ctx65cs...gave each set a mb quart dsc450, each amp bridged and they sounded great..where is the slope at on your crossover?
Enclosures
Old 04-12-2013, 12:36 PM
0/11 sssssss11
I have the passive crossovers that come with the components and I have the speakers cut off @ 100 on the head unit. I have a crs z9 and I'm letting the amplifer run a full signal to the passive crossovers. The speakers are low in the door..just not a lot of mid bass coming out for some components running 100 watts. I have to turn the bass up a lot to get some more bass on the head unit..is it maybe the components?
Old 04-12-2013, 01:01 PM
0/11 sssss8594
the crossovers come with 2 different slopes inside of them...theres a switch...and having the amps on full will cause lack of midbass and harsh tweets...setup the amp properly and you will be happier
Enclosures
Old 04-12-2013, 01:25 PM
0/11 sssssss11
Really!!! I seriously had no idea I will jump on that tonight no wonder my tweets are harsh!!!
Old 04-12-2013, 01:26 PM
0/11 sssssss11
And the actual passive crossovers have a switch?
Old 04-12-2013, 01:27 PM
0/11 ssssss108
Having the amps on full will cause a lack of midbass? That's ths first time I've ever heard that, care to enlighten me?
front stage help... NEVERDONE Sound Quality Area 22 01-18-2012 01:45 AM
I need some front stage help... grimreper912003 General Car Audio Discussion & Questions 8 12-27-2011 01:36 PM
Front Stage KcRidin09 Team Teamless 5 05-03-2010 05:34 PM
help me with my front stage?? statonburrell General Car Audio Discussion & Questions 35 11-16-2009 02:22 PM
Front stage help gbo559 General Car Audio Discussion & Questions 22 09-22-2009 02:24 PM
