need help with Zapco dc650.6 - Car Audio Classifieds!
Old 04-20-2013, 12:25 AM
0/11 sssssss56
Default need help with Zapco dc650.6
I just picked one up and I need as much help as possible.
Can I use 1 symbilink input and use all 6 channels active still?
Also I see jumpers on the transmitter, what are they and how do I use them?
Right now I have the symbilink sldn.btl.f which is speaker inputs, I can use that for oem intergration? If I want to use with after maket deck with RCAs id get the transmitter with RCA and long din cable and mount transmitter and install as close to deck as possible?
Old 04-29-2013, 06:05 AM
chrisbarrett27's Avatar
0/11 ssssss127
Hey man I can help you out as far as the jumpers on the transmitter. I just picked up an 1100.1 myself and have been figuring it out. There is a diagram on the transmitter that will say 0db, 6db and 12db. This basically indicates the boost you will get depending on how you set up your jumpers. It's pretty easy to figure out. Most guys set it up for 6db but I did 0db which is basically no boost at all. I like setting my gains with a dmm, so having a boost on there screws my numbers up so I'm not sure how to compensate.
And yes, put that transmitter as close to the deck as possible, just get you an 18ft cable to run back. The cables work great. I have mine running along my 0 gauge power wire and I get absolutely no interference at all. Hope this helps you out. Did your amp come with a manual? If not I'd download it. Hopefully the manual can answer the rest of your questions. Take care and good luck!
Chris
Old 05-10-2013, 02:11 AM
0/11 ssssss127
Did you get this beast figured out?
Old 05-14-2013, 01:28 PM
0/11 ssssss147
One cable will do 2 channels. The jumpers are for what the guy above said...
Zapco DC650.6 and DR-SLC Bobbydenorv Multi-channel Amplifiers 5 04-26-2013 12:58 PM
need help with Zapco dc650.6 AClassSounds General Car Audio Discussion & Questions 0 04-20-2013 12:24 AM
used zapco dc650.6 chrisboomers Multi-channel Amplifiers 14 07-15-2011 02:10 PM
Zapco DC650.6 jagblazer01 CACO Birthsheet Archive 0 02-04-2009 10:30 AM
[SOLD]Zapco dc650.6 DUMPED Multi-channel Amplifiers 15 01-19-2009 12:04 AM
