Ground loop isolator?? - Car Audio Classifieds!
Old 05-16-2013, 04:45 PM
Rocken JBL's Avatar
0/11 ssssss941
Feedback Score: 21 reviews
Default Ground loop isolator??
are they worth getting? what brand should i get. What do they do? what amperage should i get and what does the amperage matter as far as the isolator goes?
Probably would put this on my sundown 125.4 not sure if i even need one just wanted to see
Owner-The Dog Pound Car Audio Club, Owensboro
-Team Sundown Audio
-FCBC 200 MOD Champion 2012
-Runner up 200 SD Champion 2011/2010
-MECA AS2 Kentucky state points Champ in 2010
Old 05-16-2013, 05:42 PM
TNJ
0/11 sssss7882
I used one once, it solved the problem, but like wheresthebutta once told me "you're simply hiding the problem, not fixing it" and he's a sq beast. Is a quick fix, but not the "right" fix. I used the ones from crutchfield I believe. They're simple items.
Old 05-16-2013, 05:54 PM
Rocken JBL's Avatar
0/11 ssssss941
the thing is is that i dont have a problem i just was unaware of how they worked or if it would take my very little noise and turn it into no noise... i dont have any alt whine but a VERY faint amp signal noise.... i thought they may be a good addition for sound quality.... just wasnt sure about them. also, what about the amps they are rated for? waht does that mean
-Team Sundown Audio
Old 05-16-2013, 06:11 PM
They won't get rid of your noise floor. They provide a "clean" reference ground for the signal which can eliminate alternator whine, pops, chirps, and other electrically induced noises. GLIs aren't really rated in amperage, as the signal current is extremely low. There's inline power noise filters that are necessarily rated in amperage. Those are just capacitors to filter a/c ripple on a d/c line. Different thing altogether though.
My take on GLIs: while it's always best to have the fewest possible components in your signal path, the reality is that there's a ton going on electrically in a car. In most instances of noise where all they typical stuff (wires routed and terminated correctly, etc.) is addressed, they can be lifesavers and will not add any audible degradation of the signal. There's no reason to preemptively install one though.
Old 05-16-2013, 06:27 PM
Rocken JBL's Avatar
0/11 ssssss941
ok thank you all so much... i will probably hold off on that then... they are very cheap but no need to get one if not needed
-Team Sundown Audio
Old 05-16-2013, 07:07 PM
Loyal Member
0/11 sssss1788
I have like 3 of them and I never knew what they were for.
chassis ground = horrible ground loop? nicyousuckk General Car Audio Discussion & Questions 4 03-01-2011 12:32 PM
Question about ground loop rxer311 General Car Audio Discussion & Questions 18 08-21-2010 01:52 PM
ground loop isolator problem Memphistahoe02 General Car Audio Discussion & Questions 0 05-23-2010 11:07 PM
Ground loop isolater aturcotte127317 General Car Audio Discussion & Questions 9 11-16-2008 01:09 PM
