Slowing music q's - Car Audio Classifieds!
Old 06-18-2013, 10:23 PM
Twitney181's Avatar
0/11 ssssss591
Default Slowing music q's
Idk why it would, but does slowing music with audacity introduce clipping? Or is this my own fault for sending a dirty signal. Original song clipped already? (Some were decaf) I ask cause I got my sp4 in today and last night I slowed a bunch of songs from 26-31hz and it's killing it right now, but after 10 minutes the dust cap was a little warm, back the gain off?
Specs
1 fi sp4 15
Box- 5.33 cubes tuned at 28.76hz
Temporary amp for long drive this weekend is a ss rub1.1600
Ssf is set around what is guess to be 21-22hz
Old 06-18-2013, 10:47 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Edit:
Didn't see what you were tuned to.
Could be getting warm cuz it's not broken in yet.
Try free airing it for a couple hours on like a 20hz tone.
Then try it in the box again
Old 06-18-2013, 11:04 PM
Twitney181's Avatar
0/11 ssssss591
Originally Posted by blkbeater View Post
Edit:
Hmm so it's not from playing to low right? I don't really have the time for that before our trip :/ any other reasons? It's not like it was hot, just slightly warm
Old 06-18-2013, 11:13 PM
Twitney181's Avatar
0/11 ssssss591
Idk if its normal, but the dual 1.27's gave me 1ohm. Is that right??
Old 06-19-2013, 12:49 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Lower notes draw more current therefore your voltage drops more, which can cause clipping. You're sub isn't cycling as quickly, but in general kind of "mindstate" you can think in is lower = longer, therefore the woofer needs more hard push energy because the moving parts have to move further in a single stroke. But kind of, depends on box tuning. Play below tuning can cause your voice coil to heat up more quickly as well.
If it's just warm though, you are fine. They are meant to get warm, even like really really warm. There is a threshold, but you have a high quality woofer built for abuse.
Old 06-19-2013, 01:00 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
If your SSF is at 22, then it's still going to let a decent amount of 22hz and even under that pass. it's not like you set it to 30hz and it will be a perfect filter. You gotta go up a bit. set it to at LEAST what your box is tuned at. Yes, it's not going to be as loud...do you wanna play loud for a few minutes or have the subs last?
And you need to open the song in audacity and then see if it's already clipping at first. It should show up red in the clipped parts right away.
Go into view > show clipping and make sure it's enabled. Might be different for other versions, but I'm running 2.0.3
In the red is the clipped signal which I amplified a crazy amount as an example.
Also, are you monitoring the voltage at all? You didn't mention any voltages.
team graham
Old 06-19-2013, 01:31 AM
Twitney181's Avatar
0/11 ssssss591
Thanks guys! And yeah it wasn't hot by any means at all, and the lowest my voltage saw was 12.9-13.1 at idle when coming to the stop light. Besides that 13.6-14
I backed the amp off slightly and turned my ssf up, ill play tomorrow when I go the store (7-10 minute drive) and see how she does.
Also, on this same model amp (my old one I sold, using my brothers) I ran all these same songs no prob, no hotness or burnt coil on 2 type r's.
Could it just be from the spiders being so stiff and all the extra work to get the cone and what not moving?
Lastly, how low do you think ill be ok playing below tuning? 3-4 hz? More, less?
Old 06-19-2013, 01:08 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
It's not how low you play as much as how hard you push the woofers. I agree with what other dude said. You can up your ssf and it'll roll off a little so when you play super lows, it'll still play them just not at full volume. I'm sure there's a golden range you can find. Your voltage is pretty decent so I wouldn't worry too much about bad voltage.
Old 06-19-2013, 01:19 PM
tacomaguy1's Avatar
0/11 sssss4401
nothing wrong with a warm dust cap, hot is another thing
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 06-19-2013, 01:34 PM
Twitney181's Avatar
0/11 ssssss591
Well I upped the ssf slightly and turned the gain down a tad and then went on an hour drive and she didn't even heat up at all
4 Fi Q's 12" fiji24 12" Subwoofers 5 08-12-2012 01:52 PM
Slowing down an remastering music anyone? Hector_509 General Car Audio Discussion & Questions 15 07-01-2012 02:03 PM
audiopipe 3k q's iKidwell General Car Audio Discussion & Questions 44 12-27-2010 12:55 PM
Port q's biscuit Enclosure Discussion & Design Construction Help 11 08-16-2009 10:01 PM
upgrading q's Snwbrdr1 General Car Audio Discussion & Questions 28 02-16-2009 03:56 AM
