Explain me closed cell foam pro/cons - Car Audio Classifieds!
Old 11-25-2013, 01:19 PM
vince79vette's Avatar
0/11 sssss2011
Default Explain me closed cell foam pro/cons
I have always done spl so all I know is deadner everything 3 times lol. I have been reading more into ccf and want to know little more about it. Like does it cut down on db and does it stop certain freq? And where to really use it.
Old 11-25-2013, 06:02 PM
0/11 sssssss27
CCF is just compressible foam that will decouple the two surfaces to which they come in contact. Used properly, yes, it will be more effective for reducing vibration than just CLD tile alone, but it needs to make contact with both surfaces
Sent from my SGH-I337 using Tapatalk
The Following User Says Thank You to neo_styles For This Useful Post:
cerwinvega_fan (11-25-2013)
Old 11-25-2013, 06:53 PM
0/11 sssss2011
So u mean filling a void?
Old 11-25-2013, 06:55 PM
0/11 sssssss27
Kind of... it doesn't so much as fill the void as it keeps two hard surfaces from vibrating against each other. So more of a shock absorber. Pretty effective, too, as it took care of a lot of my rear deck issues
Old 11-25-2013, 07:05 PM
0/11 sssss2011
So do u only use it in place were let's say b pillars cover and the pillar itself and headliner and roof. And if u used it in a door would it hurt ur mid bass?
Old 11-25-2013, 07:09 PM
0/11 sssssss27
It can be used anywhere you need to keep two surfaces from coming into contact with each other where there isn't a tremendous gap in space. I use CCF in my doors to make sure I don't have any sound from my speakers leaking behind the door card (using rings that go from the outer edge of the basket up to the door card). The end result is actually a significant improvement in midbass.
Old 11-25-2013, 07:15 PM
0/11 sssss2011
Ok got ya. Is that the only place u use it at. That is were I was going to use it and I saw a thread on here with a guy using it all over his car and I was think it would hurt the output
Old 11-25-2013, 07:18 PM
0/11 sssssss27
No, it's not the only place, but my VW came pretty solid from the factory. The only trouble spot I've had is a trim panel over my rear deck which was taken care of using strips anywhere the panel and body met. CLD alone wouldn't take care of it either.
A cheap way to take care of larger gaps (don't laugh) is to buy pool noodles and cut them as needed. Actually works really well.
Old 11-25-2013, 07:20 PM
0/11 sssss2011
I have seen that before actually. So it's pretty much to keep plastic from smacking metal
Old 11-25-2013, 07:21 PM
0/11 sssssss27
Exactly what it does
WTB Closed Cell Foam taylorpro Wanting to Buy (WTB) 4 11-22-2013 10:00 PM
Closed Cell Foam. silvercookie General Car Audio Discussion & Questions 8 02-05-2013 09:37 AM
pros and cons of pro audio kurupt305 General Car Audio Discussion & Questions 13 09-12-2012 11:48 AM
Closed cell foam L a r r y General Car Audio Discussion & Questions 17 04-02-2012 10:33 PM
Pro v. Cons of MP6s and MP10s? thericanballer (Crescendo) 11 03-09-2012 08:21 AM
