2 vifa 3.5" questions - Car Audio Classifieds!
Old 04-29-2014, 05:21 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Default 2 vifa 3.5" questions
I'm thinking of getting 4 of these. 2 in each door, replacing the little storage area with a small sealed box for each side, bridging down to 4 ohms on each side.
Vifa 3 5" Speakers M K MP6 Woofers Home Audio Pair Mids Kreisel Replacements | eBay
I would cut the pole shorter and put a dust cap on them.
Also wondering how 2 of these in the center console with a tweeter in the middle of them would sound (like a center channel for home audio)
Or perhaps for use in a DIY studio monitor with 2 3.5"s and one vifa silk dome 1" tweeter for a computer setup?
team graham
Old 04-29-2014, 02:11 PM
Apex has had these for a while at $15 each and they aren't torn up.
Speaker Stuff
I haven't heard them, but those who have said they're great. I wouldn't cut the pole or do anything like that...if you don't want to use the tweets just don't connect them to anything.
As for the placement, it's not something I would ever do, but give it a shot.
graham (04-29-2014)
Old 04-29-2014, 02:18 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Speaker Stuff
I offered $9 each and got 4 of them.
What would be a good place to mount 2 of them on each side?
I'm assuming they are 4 ohm each and the tweeter is 4 ohm, which is what made them 8ohm?
team graham
Old 04-29-2014, 03:43 PM
Warning....this might get a little complicated.
Putting two speakers with the same acoustic output next to each other will begin to beam heavily as you get higher in frequency in the direction of the long axis of the speakers. See the attached picture for a representation of this, and image your ear where the red lines meet vs. your ear where the green lines meet. So if you need to use them higher than ~2khz it would be recommended that they sit equidistant from your ear so they sum correctly. Below the point where dispersion narrows they will still sum and act as one large speaker. So if they are going in the back (toward the trunk) of the door panel, put them next to each other horizontally (one closer to the engine, one closer to the trunk). If they are going in the front of the door panel (near the door hinge), you might want to put them at a slight angle (with the front one slightly higher) so that if you measured from the center of one speaker to your ear and did the same for the other the difference would be as small as possible.
Now...will it really make a difference outside of the theoretical implications? Maybe, maybe not. From a purely one axis point of view, dispersion narrowing (another term for beaming) might be good if the speaker has a rising response that needs to be tamed. Also in a car we don't just hear what's coming from the speaker in a straight line toward us, we hear all kinds of reflections. This has a twofold effect though: the combined output of all reflections means that we don't have to be as careful with dispersion issues as you would in a big open room because they will all tend to "flatten each other out", but this won't happen at all frequencies. For those areas you will see a large dip in the frequency response that can't be corrected by EQ, because no matter how much power you throw at the speaker to increase the primary beam output at that specific frequency (or range of frequencies), the environment creates its own reflection that cancels it out.
A good but long thread about this concept if you wish to explore it further: http://www.diyaudio.com/forums/multi...es-matter.html
Vifa NE19VTS-04 3/4" Silk Dome Tweeters Pieper Component & Coaxial Speakers 14 04-14-2014 12:24 AM
FS: Vifa Tweeters, Aura 6" Mids DonH Component & Coaxial Speakers 10 10-30-2012 05:15 PM
Vifa BC25SC06-04 1" Textile Dome Tweeter tez4life General Car Audio Discussion & Questions 6 10-28-2012 08:55 PM
FS: Vifa NE25VTS-04 1" Silk Dome Tweeter Inferno333 Component & Coaxial Speakers 3 08-02-2011 01:24 AM
Vifa BC25SC06-04 1" Textile Dome Tweeter nismos14 Car Audio Product Reviews 0 03-22-2010 11:54 AM
