Active Crossover Help? - Car Audio Classifieds!
Old 06-25-2014, 11:40 PM
G00burr's Avatar
0/11 ssssss591
Default Active Crossover Help?
hey guys...
this is most likely a newbie question so hopefully someone can chime in quickly.
i looked around for a while but i never found a thread that directly answered my question so here it is:
i am trying to set up 2 nendo pwx-8s in an active setup with a CT-Sounds 125.4 (don't laugh).
from what i have read, the usable frequency range is 76-5100hz but people seem to like them cut at around 3500hz.
my question is how do i cross over both a hpf and a lpf on the same channel? is this necessary? and do i need a processor?
thanks in advance
Old 06-25-2014, 11:48 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Originally Posted by G00burr View Post
hey guys...
thanks in advance
Not familiar with that CT, but the x over needs to do bandpass, not just high OR low, but both @ once.
That being said if your headunit can supply the high pass and the amp low pass goes to the 3.5k then you are ok too.
If none of these apply then external x over is needed.
Old 06-25-2014, 11:58 PM
G00burr's Avatar
0/11 ssssss591
thanks for the quick reply! it is NOT a bandpassable amp, but the lpf can go as high as 5k with a -12db slope if need be. my head unit is a clarion cz702 and has the option of 60,90, and 120hz for a hpf @ -12db as well. is this usable?
also, i'm a complete noob to this so don't mind my ignorance... what does the 10xlpf-1x-10xhpf switch do on the amp?
what would you recommend for an affordable external eq/processor?
Old 06-26-2014, 12:05 AM
Partially Unwound
0/11 sssss2697
You could do headunit and amp combo.
The x10 is a freq multiplier, it makes 500Hz -> 5000Hz or 100 to 1000.
The external is easier to tune but there are tons of choices.
The most flexible and cheap is prob a mini DSP. I am considering one if this old Kenwood 1/2 din I have is no good. Its over 20 yrs old, I am just using the band pass on my p900 now and its ok, but a pita to have to run to the trunk repeatedly to fiddle with those tiny vague knobs.
Old 06-26-2014, 12:07 AM
Partially Unwound
0/11 sssss2697
The minidsp will do lots more than most regular xovers for the $.
The 2x4 is all you need for a 2 way setup, but 2 2x4 them would be heaven.
Old 06-26-2014, 12:18 AM
G00burr's Avatar
0/11 ssssss591
wow. the 2x4 looks promising. does it come with all of the cables needed to program it? and also, is there anything else i need to get for car audio purposes? i feel like it's going to be very fragile haha
Old 06-26-2014, 12:20 AM
G00burr's Avatar
0/11 ssssss591
oh, and are you able to do 2 different crossovers on both sets of outputs?
like if i had a set of tweeters for the other two channels?
Old 06-26-2014, 01:36 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Not really sure how "SQ" electronic crossovers are, but they are cheaper than DSP's and would do what you need.
team graham
Old 06-26-2014, 06:56 AM
Partially Unwound
0/11 sssss2697
You want the 'in a box' version most likely since it has higher pre out voltage and 1 dc power conditioner per unit
you can set it up any way you like - 1 for each side \ 1 for tweets \ 1 for mids \ you program it similar to an rf 360 with computer and usb cable
Old 06-26-2014, 07:05 AM
Partially Unwound
0/11 sssss2697
Yes plain xover is cheaper, but the extra flex of those units almost justifies the cost.
If you just want to totally customize your 2-way setup for about $110 I am unaware of any better options besides swapping head units or using a way more expensive DSP like a 360\MS-8\etc...
4 way active crossover d77543020 eBay 0 02-16-2013 08:35 PM
WTB active crossover jmkanek Wanting to Buy (WTB) 2 04-21-2012 01:16 AM
Active Crossover appleyard General Car Audio Discussion & Questions 1 06-28-2010 11:40 AM
Active Crossover Drunken.Swagger General Car Audio Discussion & Questions 9 01-30-2009 09:54 AM
