crescendo cz 5.25" questions - Car Audio Classifieds!
Old 08-07-2014, 09:25 PM
0/11 sssss1882
Default crescendo cz 5.25" questions
So I just got hooked up with my first set of components. The tweets are a little bright, and midbass is lacking. I literally just threw them in for a test listen using the crossovers that were sent in the package.
I've read about midbass drivers needing time to break in like any woofer, so I'm curious if it'll liven up some as time passes. Any insight to this?
Also, if I were to not run them on the passive crossovers, can anyone suggesting a starting point to set my crossovers on the amp. If I were to do it that way I would run mids and tweets on separate channels obviously. Using a PPI black ice 800.4. Run my mids on channel one and two/ tweets on channel 3 and 4 for obvious cross over differences. Right now I have them set on full range running on channels one and 2 to the passive crossovers. I wasn't sure if I should run only high pass and thought I'd let the crossovers work their magic.
I'm in a 1996 jeep Cherokee. Mids are mounted in stock door pods with the interior of thebnpanels deadened as well as sealed off with more deadener. I have my tweets mounted on the dash for the time being, angled towards the windshield so it can rollnoff and spread instead of blaring in my ear.
First time running anything other than coaxials. Just curious on any advice, thanks.
Old 08-08-2014, 02:12 AM
0/11 ssssss666
I'd set the tweets at around 3.8khz
And band pass the mids around 140hz on the low side and 4.5khz on the high side and tweet from there. Should give you a good starting point. I'd be easy on the gain. Without the passive crossover, the speakers aren't as forgive to abuse
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
Old 08-08-2014, 06:15 AM
0/11 sssss1882
Thanks for the advice. I can dial it in from there. I just had no idea where to start.
I'm gonna scope my gains again tomorrow and see what I can do.
2 vifa 3.5" questions graham Sound Quality Area 3 04-29-2014 03:43 PM
Memphis m3 15" questions graham (Fix My Speaker) 4 12-15-2012 03:31 PM
DC 18" Recone questions Jthomas General Car Audio Discussion & Questions 18 12-23-2011 08:05 PM
2 questions about a Plaform 3 12" MtxNeonguy937 (PSI Car Audio) 1 08-11-2011 12:12 AM
RD 18" heavyweight questions rsanch General Car Audio Discussion & Questions 6 05-20-2010 03:15 PM
